Quick question...
What size drill bit should I use so that
i can cut a M6 thread?
Paul
last job before SVA
5MM
hth
Ray
Easy way to work out size
6x1.25mm =-1.25 =4.75 tap
8x1.25mm=-1.25 =6.75 tap
10x1.5mm=-1.5=-1.5=8.5 tap
and so on.
and so on.
Or, use of these here puppies.
Makes the job a real piece of cake.
Your local grumpy engineering supplies shop buried on an industrial estate soemwhere will have them.
Little tip for drilling for ANY thread size is to take a nut and for the thread you want to tap and find the largest drill bit that goes through
it.
Works with all thread types
Little tip for drilling for ANY thread size is to take a nut and for the thread you want to tap and find the largest drill bit that goes through it.
Plenty of charts on the net, got a few for various jobs i use.
This one is pretty easy to read
linky
and another
[Edited on 10/2/08 by bob]
Great tip that!
