Author: Subject: Track front and rear
b14wrc
posted on 1/9/13 at 04:03 PM Reply With Quote
Hi all,
I previously asked some questions regarding my rear suspension design, I'm now looking at starting the final detail design of the front end suspension now that the rear is almost completed.
Question is:
Should my front end be slightly wider, the same or narrower than my rear?
I have seen quite a few varying layouts and as the previous thread states track does not really effect handling as much as other factors. But I still need to decide, so any ideas?
My rear is now set at around 1470mm.
Regards, Rob
20vt powered rear engined locost
NigeEss
posted on 1/9/13 at 04:37 PM Reply With Quote
Ideally you'd want equal track but 99% of us won't notice a couple of inches less at the front......
....except....if you try to place the front wheel on the perfect apex the rear will clout the kerb
Volvorsport
posted on 1/9/13 at 05:01 PM Reply With Quote
Since your mid rear engine . I expect you'll need a wider rear track
www.dbsmotorsport.co.uk
getting dirty under a bus
davev8app
posted on 11/9/13 at 09:56 PM Reply With Quote
i have seen a lot of cars have the widest track at the heavy end
b14wrc
posted on 11/9/13 at 10:52 PM Reply With Quote
That 20vt is heavy!
