Slimy38
posted on 8/5/23 at 08:42 PM |
Roll bar triangulation opinions
following on from my previous post, I've mocked up a roll bar with bracing.
I've come from as high up on the hoop as I can get, then out to the side of the car before coming down the side in line with the steel. It seems
pretty strong although I wonder about the angle of triangulation. I also think that having a bend in the side bar means that I'll need an
additional fixing to the chassis. The bend is about 25 degrees.
What's people's thoughts on this?
[Edited on 8/5/23 by Slimy38]
Mr Whippy
posted on 9/5/23 at 06:41 AM |
Sorry zero out of ten. The angle is far too steep, the brace is not mounted to a strong part of the chassis, plus the brace is only supporting half
the height of the hoop. It will add no appreciable support. Why can you not do the brace in the normal way?
russbost
posted on 9/5/23 at 09:02 AM |
I don't entirely agree with Mr Whippy, tho' it's certainly not ideal - it rather depends what you are trying to achieve .
If you want full protection like the "normal" race type cage then that's what you need to go for. What you have there would provide a
little extra side/shoulder protection, something completely lacking in the standard 7 design & as it goes to around head height would certainly
reduce the moment around the mounting point of the base of the rear hoop, so it would be less likely to collapse in the case of a rollover
It would also give added support if seat belts are to be mounted on the hoop. If you braced diagonally downwards toward the rear where the bend is
that would add substantially as it splits it into 2 triangles & you could brace around the forward lower mounting point to stop that simply
ripping off the lower chassis
I wouldn't say 0 out of 10, but far from perfect
As I say, depends what you want/expect it to do - why can't you go higher up the hoop?
Slimy38
posted on 9/5/23 at 09:12 AM |
The bottom of the brace aligns with the corner of the triangle, here's a better photo;
I've not yet decided on how it fixes at the bottom, I've just used 'steel plate' (AKA piece of wood) for this example.
You have a good point about not getting all the way to the top, I'll have a think about that. I wanted it higher but I'm not sure whether
the increased angle getting to the top would then make it less effective. I can't do the 'normal' brace because my car doesn't
have the regular back end.
Slimy38
posted on 9/5/23 at 09:18 AM |
This will be a road car, so I need to get a decent balance between form and function. The main issue is that I have no 'rear', the Austin
Healey bodywork has no upper support for anything further back than the suspension tops. So I need to come forward.
I should mention it's missing the middle brace, I still need to include that as per the Haynes roadster design. But that's a horizontal bar,
midway up. That'll be for the seat belt mountings as well.
Considering you've both said going higher on the loop I think that's what I need to address first.
Slimy38
posted on 9/5/23 at 09:40 AM |
I'm thinking about alternative routes now. I could bring a bar down from the centre of the hoop on to the transmission tunnel, that would solve
the angle but not the 'strong part of the chassis'?
I can't think of any other routes that would get me from the bar to something inside the car (without removing the passenger seat of course!).
I was trying to find some other examples and found this MX5 roll bar;
I guess that's similar in that the angle is too steep? It does get to the top though, I could try and end up in the same place with the side
bars?
russbost
posted on 9/5/23 at 09:58 AM |
Where it mates to the lower front I would have a vertical plate welded to the end of the tube & add a matching plate welded vertically to the
triangulation you already have
, if the side brace is triangulated from behind where it bends & you can get a little higher up the hoop & add a central support down to the
transmission tunnel even if that isn't massively strong it all adds to the overall strength & stiffness - problem is, you don't want to
finish up with it looking like a climbing frame!
Don't forget with the seat belt mounts the top point of the belt needs to be 450mm above the block they place in the bottom of the seat - that
height is something it's easy to fall foul of on a roadster type car
Slimy38
posted on 9/5/23 at 11:01 AM |
That's great advice, thanks. As it is the whole of the side bar is hidden inside the bodywork, it's only actually visible from just above
the suspension top. Triangulating the bend is a good plan and easily doable, it's behind the seat and out the way. I do just need to resolve the
height, I'll see if I can get 'mockup version 2' up to the top of the cross bar.
And thanks for the block reminder, I'll be double checking that one as the cross bar goes in.
adampage
posted on 9/5/23 at 03:25 PM |
What about....?
Hey Slimy38,
Just a thought but..... When you say "there's no rear, there's no upper support" - could you not go down to the top of the diff
cage or top rear wishbone mounts, there must be some good structure there?
You could even do an X where a bar from the top-left corner of the rollbar goes down & back to the top-right of the diff cage and vice versa,
crossing in the middle.
You might need 2 small holes in the rear bodywork to go down through there, but if you look at a Cobra rollbar / rollhoop it usually has something
like that and you can make it look nice by finishing around the holes/mounts.
Then the only other thing I thought is you need to take care with a bar going out slightly wider than the roll bar and a little bit forward, because
there's a risk that in an impact the driver's head moves around if you're thrown about a bit and you don't want that bar to be in
range of banging your head on it. Might be worth checking by sitting in the seat and swinging around to see if you can whack it with your head......
Good luck, keep refining it!
Ad![](/images//smilies/wink.gif)
Slimy38
posted on 9/5/23 at 03:58 PM |
quote: Originally posted by adampage
Hey Slimy38,
Interesting idea, and while there is some good structure there, it's also where the fuel tank will live;
But I do need some more support structure to finish off the tank 'shelf', I wonder how much extra work it would take to extend it enough for
a couple of roll bar supports. I'll refit the tank and see if there is a straight line, thanks for the idea.
Ad
At the moment I'm ok, the seats don't slide back far enough to be inside the bar hoop. But that is one of the worries I had if I bring the
side bars up to the top of the hoop, at that point it might end up being in head range.
adampage
posted on 9/5/23 at 06:27 PM |
Aaah…
OK, so might not be possible but you never know!
Good luck with it, I bet it looks great when it’s done ![](/images//smilies/smile.gif)
adithorp
posted on 9/5/23 at 08:29 PM |
Not sure about the kink in the brace. Any force pushing the bar forwards would risk the brace bending at that point and thus let the roll bar
collapse.
http://jpsc.org.uk/forum/
Slimy38
posted on 10/5/23 at 07:10 AM |
collapse.
Yes, that's my worry too, I'm effectively introducing a weak point. There's a few options there though. First is what russbost
suggested, triangulate it. That should be fairly straightforward, it's clear of the cabin by that point and I could get something there. The
second is to add a second fixing to the chassis. That might not be as effective, it's a separate anchor point but there is still no substantial
sideways resistance.
The third option is to connect the two sides, making a second roll bar hoop that lies just behind the occupants. Again it's in dead space so
wouldn't be difficult to implement, but then I end up with a climbing frame as Russbost perfectly described it!
I am starting to think adampage's suggestion is going in the right direction. I do need to build a frame for the tank which would be triangulated
around the diff cage by default. I just need to increase it's capacity to be a good enough fixing point for the roll bar back stays. They'll
also need to be bolt in as they'll pass through the centre of the bodywork.
adampage
posted on 10/5/23 at 08:07 AM |
You could also...
... have a diagonal or two, or an X in the bar itself, then the front or rear supports aren't the only thing. Bit like this...
![](/galpreviews/Weld-IN-Cage-scaled.jpg) ![Ariel roll bar](/gallery/Weld-IN-Cage-scaled.jpg) Ariel roll bar
Then the rear diagonals could be bolt-in as you say, and just pointed at a different location.
Bit of head-scratching in 3D to do
Ad
motorcycle_mayhem
posted on 10/5/23 at 06:48 PM |
For want of a better description, what is there in the 'A' pillar region?
If there's a substantive structure around that bulkhead, then two forward stays could connect to it. They'll have to take a slight bend, but
if substantive tube I can't see an issue. For how this works in practice, look at the Sylva Riot. This came with either a single unbraced hoop, a
bolt on set of forward stays (triangulated down to the rear bulkhead floor) or a set of forward stays welded in, without the triangulation bit. Superb
design.
Slimy38
posted on 10/5/23 at 07:12 PM |
design.
I kind of understand what you mean, in my case there is no A pillar in the conventional sense but I do have some scope to build something out. Looking
at the r1ot compared to the bodywork that I'm using, I could hide some decent metalwork inside the body;
The right image shows the body coming up quite high all the way to the bulkhead. I wonder whether I'd still have trouble on the backend though,
trying to get the bar high enough on the hoop to be effective. The r1ot comes up halfway but it is pretty much a straight line from the front.
Slimy38
posted on 11/5/23 at 08:50 PM |
OK, here's attempt two, heading backwards this time;
This is just a temporary structure to gauge where the roll bar will end up, essentially I'm aiming for the bottom rear corner of the tank. The
roll bar can be straight, the only thing that I'm slightly worried about is that it starts at the hoop bend (the blue tape). I don't think
that will make any difference though.
So this weekend I'm going to build a platform that is secure enough for the tank and triangulated enough for the roll bar. In terms of
triangulation, I'll be coming down diagonally to the lower suspension point like this;
and just to confirm the last point of what Mr Whippy suggested, here's a side on pic for the angle;
This angle is 35 degrees, with MSUK yearbook specifying a minimum 30 degrees I'm happy the bar will give enough support.
I'm still in two minds whether to keep the other bars, they do serve a purpose for side impact and they're reasonably hidden.
adampage
posted on 11/5/23 at 09:25 PM |
Looks good
I think that looks good, plenty of rear diagonals are near the bend, and if you can have the forward pair too for side impact then that’s great
I wish I had front bars on mine
Ad
James
posted on 12/5/23 at 08:18 AM |
How about something akin to Hicost's original design?
Not ideal have the forward support in the middle of the bar I guess but perhaps better than nothing.
[img]
![](/galpreviews/hicostfront.jpg) ![The Beast revealed! :-D](/gallery/hicostfront.jpg) The Beast revealed! :-D
[/img]
(Does this photo work?)
James
- Muhammad Ali
Slimy38
posted on 12/5/23 at 08:25 AM |
[img]
[/img]
James
Aha, I was after an example picture of the middle support, I could only see small ones in the '£250' book. Thanks for that, now I can see
how it might look. I'm not sure about the use of flat bar but each to their own I guess.
adampage
posted on 12/5/23 at 01:25 PM |
Petty strut
If you search for petty strut there’s a few Caterham and Westfield examples online, angled, long, short, removable, etc.
Slimy38
posted on 12/5/23 at 01:42 PM |
Excellent, thank you very much! I didn't realise it had a specific name, I can see lots of different options now.
adampage
posted on 12/5/23 at 04:07 PM |
I don't know why I didn't think of it before!
Either that or go forward to create a front hoop, but that's a bigger investment / project!
James
posted on 12/5/23 at 07:54 PM |
[img]
[/img]
James
Hicost's was definitely 2" or so round tube, not flat bar.
I had a number of extremely memorable trips in the 450bhp beast! lol
- Muhammad Ali
Slimy38
posted on 13/5/23 at 07:24 AM |
Ah that makes more sense, must just be how my brain is interpreting the photo.
