Author: Subject: wanted bike engine
george1980
posted on 4/1/08 at 06:23 PM Reply With Quote
wanted bike engine
hayabusa/zx12r/ wanetd with all running gear,
also posibly if i get sorted a 929 blade engine already in my kit with all running gear exept rad
posted on 4/1/08 at 07:07 PM Reply With Quote
Here's aZX12R on e-bay to keep your eye on.
Or a Busa engine also on e-bay
Then there's also Mal from Yorkshire Engines
Phil
[Edited on 4-1-08 by Hellfire]
mark.s
posted on 4/1/08 at 07:11 PM Reply With Quote
there's a 12R here for not alot of money http://www.pistonheads.com/sales/304093.htm
posted on 4/1/08 at 07:19 PM Reply With Quote
That engine is very good value for money, although the A1 engine did have a few issues with the clutch.
Phil
clanger
posted on 4/1/08 at 07:28 PM Reply With Quote
What were the clutch issues????
Planning on a Zx12 for a future project
Ta
posted on 4/1/08 at 07:45 PM Reply With Quote
The 2000 & 2001 ZX12R clutches lacked oiling. This was rectified in 2002 when the inner clutch hub and basket were re-designed. The oiling issues sometimes caused the clutch hub to break and/or clutch baskets to explode. The inner hub of 2002 models onwards has more holes drilled which improved oiling.
Phil
Coose
posted on 4/1/08 at 08:17 PM Reply With Quote
Which probably means that if you buy an '00 or '01 motor it could be rectified by using a later basket?
Spin 'er off Well...
StevieB
posted on 4/1/08 at 08:22 PM Reply With Quote
Definately worth giving Malc a ring before you buy anywhere else
posted on 4/1/08 at 10:30 PM Reply With Quote
Yes, you can resolve the clutch issues by using a later hub and basket but neither of these two components are cheap. There were also other improvements made on the later B models.
Phil
