Cosworth roller ITB vacuum take off needed
se7ensport - 18/8/20 at 07:46 PM
Hi folks
Help needed... I have Cosworth roller ITBs and require a vacuum take off for the blipper to work, there are bolts on the top and the bottom of the ITBs, my guess is that the top are used to balance them and the bottom are good to use, can anyone confirm? Any service manuals to support appreciated.
Alex
peter030371 - 20/8/20 at 02:32 PM
I have Titan roller ITB on my Duratec and yes the top screws are a balance bleed off type thing which means you should be safe to use the bottom ones I would think. Not 100% certain but 99% sure if that helps!
