posted on 29/5/13 at 11:32 AM |
FS - Triumph Rocket III Engine
Triumph Rocket III bike-engine for sale!
Surplus to requirements as I've sourced a black engine and everyone knows the black ones go eleventy-million MPH faster than silver ones
Comes with TB's (secondary butterflies removed), all sensors except oil pressure (a £26 part), oil-tank, and a bike driveshaft that you could
bastardise to suit your project (these are a few hundred quid on the secondhand market!).
No starter. No ECU (you wouldn't want a standard one anyway as it chokes the engine, and the software to unlock it is as pricey as a new Omex,
DTA, etc).
These things would be great in a seven-type car... bike-engine lightness, but 2.3 litres of torquey goodness!
Sequential box. Dry-sumped as standard. Cable clutch for simplicity!
Tuners have established they can run in excess of 8K... some run them at 9k. An aftermarket ECU and good tuning should unleash Hayabusa-humbling
performance! TTS have dug around in them and even offer a supercharger kit if you are so inclined.
I'd need £1595 for it which is cheap considering the rarely come up for sale.
There's a fire-damaged one on ebay with no ancillaries for £1k and a recon one for £2.4k. The average price from the States is usually just
over £2k landed.
It's Evolution Baby!
twybrow
posted on 29/5/13 at 11:52 AM |
Scootz - the software/hardware to 'unlock' a standard ECU is not super expensive. It is called Tuneboy, and it costs less than £350 (you
need a special cable, and the software that goes with it). What you end up with is a fully 'unlocked ECU, with full access to everything from
the fuel and ignition maps, to diagnostics, and sensor information - much more than you would get with a Power Commander.
Good luck with the sale - it could make a cracking BEC!
posted on 29/5/13 at 12:28 PM |
Thanks for that... and appologies for not making myself clear.
I don't have a Triumph ECU, so that would have to be added to the cost of the 'tuneboy'. This would likely take the overall
cost into Omex, DTA territory. TBH, if the prices were comparable, then I'd personally prefer to go down the aftermarket ECU route as these
usually have better functionality than OE ones with 'piggy-back' systems.
I've also found that dyno-tuners prefer to concentrate on certain ECU's with Omex's and DTA's being amongst the most common.
I just feel that this would translate into a better set-up engine.
I could be wrong though... I frequenly am!
PS - those single-seater engine covers are still available! Do you know of anyone down your way that could use them? I'd take £100 for both
just to free-up some space.
mookaloid
posted on 29/5/13 at 12:31 PM |
That's certainly got some potential
http://www.carpenterracing.com/RIII.htm
posted on 29/5/13 at 12:35 PM |
They're sleeping giants Mook!
From what I've read 200hp and 200ft/lbs are realistically achievable without digging too deeply into the guts of the engine, or dishing out too
much dosh!
posted on 29/5/13 at 07:42 PM |
There's one round here in a bike with a supercharger on it.
posted on 16/7/13 at 01:24 AM |
I have a starter motor and a prop-shaft for it now!!!
The starters are pretty expensive, so the price will have to go up... but only by £100 (I'll absorb half the starters cost to help shift the
engine)
£1695 for the lot!
swanny
posted on 16/7/13 at 07:48 AM |
is there a reason why these havent been more popular in kit cars?
i saw one in a mini sprint car a couple of weeks ago, that must have gone well http://en.wikipedia.org/wiki/Mini_sprint
Mr Whippy
posted on 16/7/13 at 09:39 AM |
I'm hugely disappointed that this just a piston engine, the title is so misleading
posted on 16/7/13 at 10:23 AM |
... and there's not 3 of them either!
