Raptor RB project
Rossmcleod - 28/6/15 at 08:19 PM
I'm new to the kit car forum
Hi guys
The project has started
My plans
Kit car with a skyline engine
Target weight 600 kg
Standard skyline engine puts out standard 320ishhhhh give or take
Rossmcleod - 28/6/15 at 08:34 PM
Skyline engine
Dopdog - 28/6/15 at 08:38 PM
that is one massive engine. Looking forward to more pictures and progress reports.
marco - 28/6/15 at 09:04 PM
250hp Standard.
Going to watch this carefully, I've owned a lot of skylines, tuned and rebuilt the engines and done a full conversion previously although not in a seven chassis.
Rosco86 - 28/6/15 at 09:11 PM
Looks like it could be a nice build!
Rossmcleod - 28/6/15 at 09:36 PM
Originally posted by marco
250hp Standard.
With a map and a few bits and bobs it will go to 320ishhh stage 1
[Edited on 28/6/15 by Rossmcleod]
gaz_gaz - 29/6/15 at 04:14 PM
I done a RB25 swap into an S13 about 10 years ago and weighed the motor and box before fitting. From memory the dressed engine and box weighed in over 300kg. 600kg maybe a little optimistic.
Rossmcleod - 29/6/15 at 05:04 PM
It's very optimistic mate the engine weights about 300 and the gearbox is 45kg ha ha
it's very optimistic a lot of stuff can be taken off because a don't need it like aircon and stuff
wylliezx9r - 29/6/15 at 05:33 PM
With that much torque I don't see weight being a problem.
scudderfish - 29/6/15 at 05:37 PM
OK, I'll be the first.....
Can I have a go when it's done?
Rossmcleod - 29/6/15 at 06:44 PM
Ya no prob lol
It's going to be lively wee beasty ha ha
Rossmcleod - 13/7/15 at 05:26 PM
Over night parts from Japan
Doctor Derek Doctors - 13/7/15 at 07:32 PM
But hector and his crew are going to be running Civics with Spoon engines....
Rossmcleod - 13/7/15 at 09:09 PM
Good for them
I'm going to leave there arse on the starting line ha ha
Rossmcleod - 17/7/15 at 09:41 PM
It's crazy the difference from new to old
Rossmcleod - 25/7/15 at 11:04 PM
Little update
Getting the roll cage welded together
Rossmcleod - 2/8/15 at 09:10 AM
Wee update
Frame is finished going to powder coat next week
Rossmcleod - 5/8/15 at 08:03 PM
Not much has happened waiting on the frane coming back from the powder coater.
On the plus side new 1.5mm head gasket has arrived
Rossmcleod - 19/8/15 at 05:45 PM
Frames back from the powder coater
Next job is fit engine do wiring
After wiring finished I get to pick it up and the project is all mine
[Edited on 19/8/15 by Rossmcleod]
Rosco86 - 19/8/15 at 06:48 PM
Looking good, did you have the chassis blasted before powder?
Rossmcleod - 19/8/15 at 07:29 PM
Sand blasted mate
Rossmcleod - 27/8/15 at 07:42 PM
Front inlet plenum arrived this morning
The front inlet plenum usually exits in the middle so this one has been modified
[Edited on 28/8/15 by Rossmcleod]
Rossmcleod - 27/8/15 at 07:45 PM
So a brought a r34 standard intercooler vs r33 standard intercooler
Here's a pic comparing the 2
The r34 is a wee bit bigger and a wee bit thicker
A also sandblasted it to give it a clean and then blasted it with air :grinno:
Then hung up to paint
Painted with primer then 1st coat of black
CosKev3 - 28/8/15 at 07:59 AM
Jesus it will be a handful! :O
Rossmcleod - 23/9/15 at 09:40 PM
Little update
Fitted the base to the frame
Also test fitted the engine make sure it fits
[Edited on 23/9/15 by Rossmcleod]
Ugg10 - 23/9/15 at 09:49 PM
Nice project, was very clise to buying a spaceframe anglia with this running gear in it about two years ago.
Any reason you used standard rivets on the floor rather than the big head ones that spread the load more? Encased prop tunnel is interesting though.
Rossmcleod - 23/9/15 at 10:15 PM
There isn't really much weight on the floor anyway
A might fit bigger rivets later if a feel it needs it
CosKev3 - 24/9/15 at 07:15 AM
I would change them now,the floor has to take the weight of you or your passengers standing on it whilst getting in/out of car.
Looking at pics your having this built at SKC?
Rossmcleod - 24/9/15 at 01:17 PM
Yes there building a bit of it
I mean there only doing the wiring and am doing the rest
sdh2903 - 24/9/15 at 01:31 PM
You really could do with a load more rivets. The smaller head ones are fine but need lots more or Mr IVA man won't be happy. I'm sure it comes under general construction standards somewhere. Most people have rivets pitched around every 50mm/2".
The bigger head rivets are best for riveting bodywork/fibreglass.
Rossmcleod - 29/9/15 at 09:55 AM
Picked up the frame
Now time to build myself
Fun and games begin
Rossmcleod - 30/9/15 at 06:09 PM
Brake lines the night :-)
Rossmcleod - 15/10/15 at 09:30 PM
It's slow but spent a few hours the night doing the brake lines
Rossmcleod - 18/10/15 at 01:36 PM
Few hours this morning
Few more pics
CosKev3 - 18/10/15 at 02:39 PM
Where do your master cylinders/brake pipes come out through bulkhead?
If that T piece is for a brake light pressure switch they are better mounted so the switch points towards the ground,as people have had issues bleeding up the brakes with the switch mounted facing upwards.
Rossmcleod - 18/10/15 at 03:47 PM
This is what a have so far mate
I'm waiting on a new tee (that ones ducked) so it's just sitting there for the time being then a will pipe it up
[Edited on 18/10/15 by Rossmcleod]
Rossmcleod - 29/10/15 at 10:51 PM
Fuel lines sorted till fuel tank is fitted and engine in
Plus grp panels arrived
Picking them up
CosKev3 - 29/10/15 at 11:02 PM
Will your diff fit in with fuel lines where they are?
Rossmcleod - 29/10/15 at 11:05 PM
Honestly not sure maybe
The diff is arriving next week we will find out then
CosKev3 - 29/10/15 at 11:11 PM
Oooppps.
Fitting the diff is a good idea before running your brake and fuel lines.......
Rossmcleod - 29/10/15 at 11:18 PM
Bit late now
Worst comes to it a can move the fuel lines
[Edited on 29/10/15 by Rossmcleod]
Rossmcleod - 30/10/15 at 10:37 PM
Fitted the arms and coilovers
Front coilovers
Rear coilovers
Rossmcleod - 6/11/15 at 08:37 PM
Fitting side panels
Temp fit before proper fit
Had to cut the panels
The frame is 6 inches bigger than ur normal frame because of the size of the engine
[Edited on 6/11/15 by Rossmcleod]
CosKev3 - 6/11/15 at 09:03 PM
What are your plans for the side panels?
Did SKCC recommend the Gaz coil overs?
Just wondered as I know the chassis is built by MK and they don't recommend Gaz,they use Protec now.
Rossmcleod - 6/11/15 at 10:13 PM
Planning on making a vent to cover the gap
The 3" exhaust exit is there too so will build something
Rossmcleod - 6/11/15 at 10:14 PM
What's wrong with gaz coils
Rossmcleod - 8/11/15 at 10:31 AM
Why do they not recommend gaz
Did they not use gaz before they changed to protec
CosKev3 - 8/11/15 at 11:14 AM
Yeah they did use them before.
Drop Danny a message on here and ask why they are better,didn't go into details just said they no longer use Gaz due to Protech being better for around the same cost.
Rossmcleod - 8/11/15 at 04:50 PM
A thought u knew that's why your bringing it up
Rossmcleod - 19/11/15 at 11:20 PM
Here's a few more pics
Spend a few hours the night cutting the other panel and riveting first panel on
Rossmcleod - 20/11/15 at 06:51 PM
Cut the other side and started minting panels
Rossmcleod - 22/11/15 at 07:18 PM
It's been a productive Sunday
Spent a few hours fixing the panels one side
Plus also fitted the arms
Rossmcleod - 2/12/15 at 07:47 AM
Finished off fitting other panel and fitted arms
Plus more parts arrived
Rossmcleod - 2/12/15 at 10:56 PM
Diff fitting the night
Darek32 - 2/12/15 at 11:45 PM
Nice build.
Looks like fuel lines need no replacing.
Rossmcleod - 2/12/15 at 11:53 PM
Originally posted by Darek32
Nice build.
It was a tight fit
Rossmcleod - 7/12/15 at 09:30 PM
Suspension fitted
It's coming together
Rossmcleod - 17/12/15 at 09:22 PM
Few more bits arrived
CosKev3 - 18/12/15 at 05:59 AM
Some nice parts there
Are they cortina spec front uprights?
[Edited on 18/12/15 by CosKev3]
Rossmcleod - 18/12/15 at 02:55 PM
Shiny bits
New pedal box
Rossmcleod - 25/12/15 at 01:45 PM
Rad fitted and mounted last night
[Edited on 25/12/15 by Rossmcleod]
Rossmcleod2012 - 3/2/16 at 12:13 PM
Spent a few hours today fitting rear panel
Next will be the arches and hubs when they arrive
Rossmcleod2012 - 3/2/16 at 12:14 PM
Few more pics
I've temporary fitted the panel just trying to decide where to fit the petrol cap
Rossmcleod2012 - 14/2/16 at 09:29 PM
Engine
Plus stuck the front wheels on gives me a idea how wide the cars going to be
Spent a few hours this morning cleaning head and fitting the head gasket
Timing belt is next
Brought a new one but the wrong size given lol waiting for the right belt to arrive then that's next on the list
Rossmcleod2012 - 27/2/16 at 06:57 PM
Temporary fitted the intercooler
R34 intercooler blocked one of the outlets and moved it into the top like the other side
Then painted black
It's a tight fit thankfully a decided a didn't want to run a oil cooler because there's no space
Rossmcleod2012 - 2/3/16 at 04:23 PM
Engines coming together
Tiger sealed the rear bulkhead sheet on the night
Also cut the carbon plastic sheet did fitted that too
Rossmcleod2012 - 4/3/16 at 12:26 PM
Fitted the engine the night
It was a pain in the arse but we got there
A have a ruff idea what's happening with the pipework and stuff
Wolf1e - 5/3/16 at 02:04 PM
Hi there
Great build mate. Looking very nice. Going to be a quick one!!!
Quick question, what is it that you have used for your boot panel pieces and where did you get it from?
Wolfie
Rossmcleod2012 - 6/3/16 at 01:03 AM
It's a plastic carbon affect sheet mate
A brought it from Scottish kit car 01620 880763
Rossmcleod2012 - 9/3/16 at 11:28 PM
Little update
zx12r dug - 11/3/16 at 05:52 PM
Originally posted by Rossmcleod2012
Little update
That carbon effect plastic on the rear expands and flexes in the sun
Rossmcleod2012 - 11/3/16 at 11:13 PM
Never thought of that
Looks good the now (a think)
A might change it one the car is finished
A have a idea for storage at the rear
Need to get the car running first
[Edited on 11/3/16 by Rossmcleod2012]
Rossmcleod2012 - 14/3/16 at 05:41 PM
Picked up the gearbox
Refreshed and painted
Rossmcleod2012 - 19/3/16 at 06:11 PM
I'm waiting on a few bits arriving before fitting the gearbox
I've started finishing off the brake lines
Back brake lines
Front lines
CosKev3 - 19/3/16 at 10:55 PM
Coming together
Are they cortina copy front uprights?
Pretty sure I've seen people say on here they have failed IVA for the front flexi brake hoses being fixed through the fibreglass body panel like yours are,they need to be on a bracket attached to chassis.
Rossmcleod2012 - 19/3/16 at 11:20 PM
Will double check about the flex hoses mate
A seen a car with it done and thought not a bad idea lol
CosKev3 - 19/3/16 at 11:55 PM
Pretty sure it's a failure because the fibreglass panel can flex/move,this can then lead to the solid/copper brake pipes fracturing.
Interested about the hubs/uprights as I thought the MK Indy R was designed to use Sierra geometry uprights?
Rossmcleod2012 - 20/3/16 at 12:56 AM
There new style alloy hubs there a few kg lighter than the standard ones
will try and find out for u
hkp57 - 20/3/16 at 11:06 AM
Mine were mounted the same way as yours and the IVA station you will be using had no problem with it.
CosKev3 - 20/3/16 at 01:18 PM
Originally posted by hkp57
Mine were mounted the same way as yours and the IVA station you will be ok with it
Yeah I suppose if he's using same place as yours they were pretty easy going!
As yours had a couple of clear to see fails that passed.
CosKev3 - 20/3/16 at 01:20 PM
Look really nice
Just wondering if all the geometry will be ok using Cortina spec ones,as my m8 built a Indy R and was told to use Sierra front uprights.
Rossmcleod2012 - 20/3/16 at 06:34 PM
what are the clear faults
CosKev3 - 20/3/16 at 08:30 PM
The side repeaters built into the wing mirrors are not visible from the rear at all,IVA tests are usually really strict on this now,hence people having to mount them in the front or rear wings to be able to get the correct angles of vision.
There was another too,can't remember now but it's in a thread somewhere on here!
[Edited on 20/3/16 by CosKev3]
Rossmcleod2012 - 20/3/16 at 08:39 PM
How do u know its not visable from behind?
Plus whats the other one if u don't mind looing into it mate cheers
CosKev3 - 21/3/16 at 01:43 AM
http://www.locostbuilders.co.uk/viewthread.php?tid=199620
Indicators in mirrors in that thread.
theduck - 21/3/16 at 07:23 AM
Foglight not being vertical was the other.
Ja5on - 18/5/16 at 10:29 PM
Great read.
Having a look at starting a kit car build myself just not sure which one.
