Zetech 1800 to type 9 gearbox
motojohn - 20/7/18 at 06:22 PM
i know may have been asked before but how hard is it to fit a zetech engine to a type 9 gearbox i only ask as im thinking of junking my very old motor for something with fuel injection .
thanks for any information
Schrodinger - 20/7/18 at 07:17 PM
It's fairly straight forward, they bolt together on most of the holes but you will need to get the correct starter, clutch and thrust bearing.
Ugg10 - 20/7/18 at 07:22 PM
And need to put a spigot bear in in the zetec crank shaft end, stock ford Sierra part.
I posted some info on this thread, I think it tells you what clutch, starter and spigot bearing to use.
https://www.locostbuilders.co.uk/viewthread.php?tid=212368
[Edited on 20/7/18 by Ugg10]
tims31 - 21/7/18 at 05:48 AM
Yep, as said fairly easy to do.
I've posted details on my build blog for a 2.0ltr zetec which is much the same.
[url=http://www.martinsfurybuild.co.uk/engine.html#ClutchGearboxBellhousing]http://www.martinsfurybuild.co.uk/engine.html#ClutchGearboxBellhousing[/ur l]
[Edited on 21/7/18 by tims31]
big_wasa - 21/7/18 at 11:44 AM
You can also get a pinto style Zetec flywheel that will take your pinto clutch and starter ect. Just add a spigot bearing.
chris - 21/7/18 at 03:31 PM
The 1.8 flywheel and 2ltr pinto clutch fit together with some minor fettling and use pinto thrust bearing so just starter motor Ls707 r I got mine on ebay £80
chris - 21/7/18 at 03:38 PM
Oops
[Edited on 21/7/18 by chris]
big_wasa - 21/7/18 at 04:53 PM
As you can see there are 101 ways to get the job done.
motojohn - 22/7/18 at 07:01 AM
thanks food for thought, im still not sure what engine i will use weather to go for something modern and fuel injected or go old school with a pinto and twin webbers
