New Topic New Reply
Author: Subject: Brake pedal panel reinforcement
Slimy38
posted on 22/8/18 at 07:16 AM Reply With Quote
One of the things I read on the interweb talked about the drivers side footwell panel flexing under braking, and I have an opportunity at the moment to reinforce it. However, I'd like to know if it's actually a thing to worry about or whether it is an uncommon occurrence.
I've used the recommended Haynes Roadster 3mm metal plate, split in two with the bottom half carrying the brake and clutch master cylinders (MX5 donor hence the hydraulic clutch). The lower half is bolted to the other half and to the chassis member at the bottom and seems fairly solid, but I know the average braking force exerted by a human can be quite significant. Obviously even though the clutch is also hydraulic it won't be adding to my troubles.
If anyone has reinforced this panel, do you have any photos showing what you've done and what benefits it's given? Or is it less of an issue than people say?
mark chandler
posted on 22/8/18 at 07:36 AM Reply With Quote
3mm is pretty hefty steel, much thicker than car manufacturers so I doubt you have a problem.
My bulkhead is 1/16" steel, I cut a spreader plate to reinforce where required, I doubt you have anything to worry about.
[Edited on 22/8/18 by mark chandler]
40inches
posted on 22/8/18 at 08:17 AM Reply With Quote
Yep, 3mm is more than man enough. Mine is still solid after 4000 miles
Slimy38
posted on 22/8/18 at 08:33 AM Reply With Quote
Perfect, thanks for the confirmation. One less thing to worry about.
pewe
posted on 22/8/18 at 11:23 AM Reply With Quote
If you do encounter flex (unlikely given your steel thickness) fabricate a brake master cylinder stopper.
I've knocked them up for the hairdressers and son's IntegraType R to good effect.
A google search will bring up several accessory ones but at £100+ it's taking the wee.
HTH.
Cheeers, Pewe10
Mr Whippy
posted on 22/8/18 at 12:38 PM Reply With Quote
It may flex although I doubt it, but even then it's not going to rip out is it? Sounds like beefing it up would be just useless extra weight. What's the thickness on a production car 0.8 - 2mm even in high load areas such as subframes and suspension mounts. If you still want to stiffen it up do it properly with webs not plates
Slimy38
posted on 22/8/18 at 01:05 PM Reply With Quote
HTH.
Cheeers, Pewe10
Oh yes of course, I'd forgotten about those. I remember seeing them when I was looking at MX5's for a donor. I think I'll keep that as my backup solution, thanks.
Angel Acevedo
posted on 22/8/18 at 02:20 PM Reply With Quote
I mounted my OBP Pedal box on top of two 25 X 25 mm X 3 mm Angle Iron welded to members D1 and the one across forming the bottom cornerof the footwell.
For you in GB would be D2
Regards
AA
New Topic New Reply
