New Topic New Reply
Author: Subject: Stamping VIN with those 5mm stamp sets
christim
posted on 8/4/20 at 03:01 PM Reply With Quote
Hi all,
Lots of threads about ways to put the VIN on the chassis (mostly suggesting engraving). However I've got a set of 5mm stamps, the sort all over ebay. Has anyone got experience going through IVA with these? Is it acceptable?
Done a test below here's what mine looks like (would then fully weld the final version onto the chassis per IVA manual)
posted on 8/4/20 at 03:35 PM Reply With Quote
Don’t try stamping box section, it will deform!
Schrodinger
posted on 8/4/20 at 03:57 PM Reply With Quote
I stamped a strip with the VIN and then welded it to the chassis and it went through the IVA no probs.
Keith
Aviemore
robertst
posted on 8/4/20 at 04:10 PM Reply With Quote
I printed out the vin on a sticker to use as a stencil, got a pen knife and cut out the letters and numbers and then etched it onto a chassis rail using a battery charger, with a cotton bud, some water and salt on the cathode (negative). Then some paint and clear laquer to avoid rust. Way tidier than stamping and no broken fingers
[Edited on 8/4/20 by robertst]
Tom
James
posted on 8/4/20 at 04:58 PM Reply With Quote
I got some nice plates engraved ready for SVA... and then completely forgot to fit them!
Rolled up to the test and it was first thing the guy checked! Fail!
Fortunately, being a very reasonable guy he let me go and find a set whilst he did the early test stages. I borrowed them from a local business (left my phone as security) ran back to the test centre and stamped them into the chassis there and then!
Anyway, the tube didn't collapse. It may have been a 19mm tube with would resist the crushing force better? Maybe. It was 16 years ago nearly!
starterman
posted on 8/4/20 at 07:17 PM Reply With Quote
I was just going to engrave the chassis direct.
christim
posted on 8/4/20 at 08:36 PM Reply With Quote
Hmmm.....Having tried several times to stamp in a straight line and get letters\numbers that are clear I've decided my OCD can't handle it! And I'll have to go for a neater and clearer option
A few good suggestions above and in other threads. Cheers all!
ianhurley20
posted on 8/4/20 at 09:32 PM Reply With Quote
I tried stamping a plate and the result always looked awful, gave up and printed a word ocument with the chassis number, cut it out, pasted it onto a piece of 25 x 3 mm steel and used a dremil thing to engrave the number. It worked well so did the same on part of my cassis and it looked good and later passed IVA. That's what I would do next time.
907
posted on 8/4/20 at 11:15 PM Reply With Quote
Originally posted by christim
Hi all,
I stamped a plate and then welded it into the chassis then sanded off the welds.
plate to be welded on chassis
VIN number onto chassis
907
posted on 8/4/20 at 11:34 PM Reply With Quote
Hi all,
I then realised that when I fitted the ally sides I covered the number up. Had to cut a slot.
We all make mistakes, as the hedgehog said as it climbed off the yard broom.
ianhurley20
posted on 9/4/20 at 06:46 AM Reply With Quote
Hi all,
Haha - I managed to do that twice, first time I moved the engine mounts onto the number, did it again and then put a fiberglass side panel where it was so then did it again, successfully, above the brake master cylinder, don't have a hedgehog though
paulc
posted on 9/4/20 at 09:28 AM Reply With Quote
I initially stamped my chassis using a set of punches.
However afterwards I was concerned the VIN wouldn't be readable once the chassis had been powder coated.
(Maybe i needed a bigger hammer )
So i had an off cut of 2mm plate engraved by a local place (Think they charged £20) and welded it to the chasssis.
Turned out to be the right call as the stamped VIN is barely visable now the chassis has been powdercoated.
Paul
designer
posted on 9/4/20 at 09:29 AM Reply With Quote
Go to the local engravers when all this virus stuff is over. It's worth a few bob.
They're cheap and will engrave whatever you want. Your name and chassis number is a good start.
christim
posted on 9/4/20 at 11:36 AM Reply With Quote
Paul
Thanks Paul that's my exact concern! I'll be giving engraving a go with my Dremel today, see how that turns out
Angel Acevedo
posted on 9/4/20 at 11:47 AM Reply With Quote
This looks pretty much "Factory" to me
It was a lucky mistake.
907
posted on 9/4/20 at 05:15 PM Reply With Quote
There's not many of us old craftsmen left.
theduck
posted on 9/4/20 at 09:02 PM Reply With Quote
I had a trophy shop engrave a piece of steel for me and then that was welded in. While I was at it I got them to engrave the manufacturers plate too
christim
posted on 30/4/20 at 08:44 AM Reply With Quote
Just for completeness, updating on the final outcome for this....decided to go with dremel tool with a high speed cutter attachment, printed out the VIN and taped it to the bar then cut.
I can live with the home-made look, haha
shortcircuit
posted on 4/8/20 at 12:16 PM Reply With Quote
I have just received a VIN from DVLA, 12 days since application. Last page attached and marked "Important - Action Required" requiring confirmation that VIN has been stamped or permanently embossed and signed by a "Dealer/garage"???
How do you get round this if self engraving, which I intend to do?
ianhurley20
posted on 4/8/20 at 12:22 PM Reply With Quote
Become creative! Do you know any petrol pump attendants? Anyone who is actually a mechanic - er sorry - a technician or .....
coyoteboy
posted on 4/8/20 at 12:31 PM Reply With Quote
As the manufacturer, surely you get to do your own signing
I'd get a laser etched plate and weld it on, but I'm picky lol.
shortcircuit
posted on 4/8/20 at 01:16 PM Reply With Quote
Thanks for the right "direction"
907
posted on 5/8/20 at 04:46 AM Reply With Quote
After stamping and welding in I took mine down to my local trusted MOT garage and for a tenner he wrote out a witness
letter on headed paper.
That was a while back so now he gets to MOT it each year. All the mechanics fuss round it. Its quite nice really.
Paul G
New Topic New Reply
