Ab swirl pot
dilley - 14/6/18 at 09:12 PM
Can someone please explain to me how the ab swirl pot works for a cbt1000rr?
Paul_Arion - 15/6/18 at 04:04 AM
I don’t think Andy supplies Swirl pots for the CBR1000RR as such - his fuel tanks have an adapter (available as a weld on option) into which the earlier Honda fuel pumps are a direct fit. A swirl pot fed from the tank is therefore not required - keeping the fuel system very simple and reliable. The Honda fuel pump is ECU controlled so the fuel system doesn’t require a pressure regulator / return line back to the tank etc. All nice and easy therefore.
I can sort some pics of the fuel system in my AB Performance Arion later if required?
dilley - 15/6/18 at 09:14 AM
Thanks for the reply, got told I had a swirl pot, thought it was odd🤣
Paul_Arion - 15/6/18 at 09:21 AM
It's listed on the website as a "swirl pot" but is simply part of the fuel tank they supply for the Fireblade (or can send the adapter for TIG welding into a standard tank).
AB Performance Swirl Pot linky
