A little ZX9r help please
CraigF - 1/7/18 at 04:13 PM
It has been a number of years since I was last here, so long that I had to re-register.
I have a zx9r MK.
Went to take it out the other day and it was stumbling on idle. so thought I would balance the carbs. upped the idle control up to 2k, and let her warm up. After about 5 mins she was nice a warm and then she simply died and will not idle.
Appears to have no spark.
Without doing a faluty towers on this car, any suggestions.
Battery is over 12volts
the engine spins over
stick coils appear fine and I have check the continuity with a multimeter
Any suggestions as to what could have happened?
Craig
40inches - 1/7/18 at 04:44 PM
This happened on a mates ZX9R BEC, after a lot of head scratching turned out to be the 100ohm resistor.
CraigF - 1/7/18 at 04:54 PM
Thanks 40inches,
I have the wiring diagram and I can see the grey wire where the resistor is meant to be , but I actually cannot see the resistor. I have to assume that it is hidden somewhere, as the car has been running for the last 10 years with the current wiring loom.
Could I simply run a spare wire with a resistor in it between the ignition barrel and the loom?
Craig
40inches - 1/7/18 at 09:42 PM
Originally posted by CraigF
Thanks 40inches,
Craig
That's what we did
CraigF - 2/7/18 at 07:22 AM
Thanks 40 inches,
Just surprised if it is that - what could have caused the resistor to stop all of a sudden.
Is it just a little 100 ohm inline resistor?
[Edited on 2/7/18 by CraigF]
