Hi,
When I collected my kit, MK said the standard sierra front caliper would no longer pass IVA since part of the caliper itself protruded outside the
profile of the wheel.
Is there an alternative caliper that can be used to ovecome this?
Lee
Hi Lee, I may be wrong, but cant see that the Sierra one wouldn't comply as it doesn't stick out as far as the mudgaurd bracket. Think you may have been given some duff advice. I would be inclined to go to your local IVA centre and get the word from there. Cheers Ray
iva manual says any wheel nuts/studs, hub caps etc must be blunted, but otherwise sounds like nonsense to me! link below for the IVA manual, i can't find anything in there that says any calipers won't pass
Not that familiar with either an MK or Sierra stuff, but if the inspector cannot get his 100mm ball to the caliper he can't fail it. However if
he can then it must conform to minimum radii.
Alan...
Are you sure it was MK and not Mr Wilwood who told yo this
Sounds bolloc*s
Wrap it in rubber
Sounds rubbish to me, also depends on the width and offset of your wheels !!!
[Edited on 7/6/09 by Ben_Copeland]
I was told the same thing about calipers when i spoke to phil at mk , he also said there will be no exclusion zone on the dash (i.e) behind the steering wheel.
Just confirming that the old SVA exclusion zone remains in the IVA manual, same 127mm I believe. As far as I can see the brake calipers are just the same as any other piece of metal at the front of the car and need radiusing.
have alok at this thread - especially the posts on 5th June
Linky
Hmm. perhaps a Dax bar is the way to go
hasn't jpindy3 just put an indy thru iva maybe worth asking him if he had any probs with calipers
tony
Hmm, sounds like i have been given some wrong info there then. Thanks for pointing this out
I've got the IVA manual downloaded now so will have a read through
Lee
Anyone got a copy of the hub image without creating an account?
Alan...
