if only i had the money
tomgregory2000 - 11/12/08 at 07:50 PM
vroom vroom
maximill666 - 11/12/08 at 07:54 PM
Nice bit of small print in the t&c's
An exchange unit will be required after the purchase, which we will arrange to pick up at our own cost. Failure to comply with this will result in your warranty becoming void and a 25% surcharge being applied
tomgregory2000 - 11/12/08 at 07:59 PM
did not see that
oh well its allways good fun to see what there is on the bay
nasty-bob - 11/12/08 at 08:13 PM
If you fancy one, you would be better off importing it yourself from HERE. Was a better deal though when the exchange rate was better. I'm going for the single turbo version. I cannot understand why more people don't use them in kitcars.
Do it!!
Rob
mr henderson - 11/12/08 at 08:42 PM
Indeed. I've looked at that site before, all seems a bit dubious. What do they want the old units for? Do they get sold on?
Why would not sending the old unit back void the warranty, anyway? And how exactly do they apply this surcharge?
I also see that it doesn't include ancillaries, despite the photo of a fully dressed engine
All seems a bit strange to me
John
[Edited on 11/12/08 by mr henderson]
Antnicuk - 12/12/08 at 08:49 AM
Hi Rob,
Hows you project coming along?
As rob says, forget that, you cant trust any second hand rotary engine, buy a knackered one for a couple of hundred and rebuild it for another £300 (with genuine mazda parts) and have piece if mind.
Rotaries can pop at any time. If these are genuine low mileage engines the water seals are well past their sell buy date. If i see 'Genuine low mileage original engine' in a 4 sale add, i think 'needs a rebuild'!
Or look at the slightly older shape car which often go rotten for a few hundred quid and take everything you need , sell what you can and scrap the shell.
The engine is basically identical but gearboxes are slightly stronger on the older car. You could build a whole locost using a 2nd generation car for less than the price of that engine.
Also just noticed this in the add
'THE ENGINES ARE THEN SUBJECTED TO A UNIVERSAL INDICATOR DYE TEST TO ASCERTAIN IF THE EXHAUST GASES ARE IN THE WATER SYSTEM; AND AS A RESULT TO DETERMINE IF THE HEADGASKET IS INTACT.'
Rotaries dont have a head gasget!
He will probably tell you it doesnt use any oil as well. which is another good sign a rotary engine is knackered, they should all use oil. If it doesnt, be worried.
[Edited on 12-12-08 by Antnicuk]
nasty-bob - 12/12/08 at 06:20 PM
Originally posted by Antnicuk
Hi Rob,
Hi Tony,
Project is coming along slowly. If you hear of any turbo engines for sale let me know. I very nearly bought one from Tiger Japanese a few months back but stupidly put it off as it's not urgent at the moment- now the exchange rate is crap and probably won't recover, typical.
I saw your videos on Youtube and am really impressed with your Stylus, you've done a really nice job. Did you do many mods to the engine in the end, or did you keep it fairly standard?
Rob
Antnicuk - 12/12/08 at 07:12 PM
Hi Rob
I ported the inlet and exhaust ports and upped the fuel system ready for a bigger turbo. The stock turbo is way too small which is why i have such high torque figures.
If i come across any i will let you know.
