J15 headlight covers
theprisioner - 6/1/14 at 02:04 PM
Finally managed to fit the headlight covers.
http://sylvabuild.blogspot.co.uk/2014/01/headlight-covers.html
The only remaining job before the blating season will be a tweaking of suspension setup.
jeffw - 6/1/14 at 02:13 PM
Need some chrome effect trim to finish them off
Jenko - 6/1/14 at 04:26 PM
I did buy the covers with my kit, and am still udecided as to how to fit them.....I quite like the look of the covers with a black frame like this:
Click
I thought doing it this way, any brackets could be hidden...Either way, the covers look great, I also want to get a set of carbon covers made up for track days.....plus I think they would great on the J15.
jeffw - 6/1/14 at 05:50 PM
I think the chrome look defines the headlights and gives a mid-60s sportscar look...
theprisioner - 6/1/14 at 06:02 PM
Certainly needs something, no idea what that alloy trim is, the black border may be easier, don't know!
deeceee09 - 6/1/14 at 06:38 PM
I have a pair to fit too. The ali angle approach is what a number of period cars used so I shall probably go that route. Any idea where you obtained the "chrome" trim from Jeff? My covers are 1/8" gauge.
jeffw - 6/1/14 at 07:29 PM
CBS...
This sort of thing
http://www.carbuildersolutions.com/uk/brushed-stainless-effect-plastic-u-edge-trim-5mm-x-3mm
avagolen - 6/1/14 at 08:17 PM
Must be the 'in job' at the moment. Just fitted mine to the Fury.
Headlamp_cover
Headlamp_cover
I made stainless brackets mounted with a 3mm stainless nut and bolt through the bodyshell.
Tapped for a 4mm screw. Polycarbonate spacer glued to the inside so that
I do not crack it through over tightening.
deeceee09 - 6/1/14 at 09:32 PM
Thanks Jeff.
nickm - 7/1/14 at 07:58 PM
Hi
Looks excellent really finishes off the front end.
Nick M
