Author: Subject: Wanted crossflow modified sump
nilocp
posted on 24/6/13 at 04:53 PM Reply With Quote
Anyone got a modified Escort sump and pickup they dont want?
Or, who actually modifies them?
ta
Colin
posted on 24/6/13 at 06:40 PM Reply With Quote
If you have a standard sump and pick up it's not too difficult to modify yourself. Failing that then Burtons may be able to help or Vulcan engines.
posted on 24/6/13 at 07:29 PM Reply With Quote
Hi Colin I've got one you can have for free if you want. I'm not to far away either only at pontefract
nilocp
posted on 24/6/13 at 07:37 PM Reply With Quote
Steve PM sent!
Colin
myke pocock
posted on 24/6/13 at 08:19 PM Reply With Quote
When you say "modified" just what do you mean and why? I have a crossflow in mine running a standard sump.
nilocp
posted on 24/6/13 at 09:08 PM Reply With Quote
The sump hangs below the bellhousing, so is very vulnerable to damage. A modified one will have some taken off the bottom.
myke pocock
posted on 24/6/13 at 09:28 PM Reply With Quote
So I take it that it is made shallower but do you have to make it wider to enable the same quantity of oil to be used? Does it still have to keep the standard baffles?
[Edited on 24/6/13 by myke pocock]
nilocp
posted on 24/6/13 at 09:53 PM Reply With Quote
You are correct. There are different thoughts on the baffles. It depends exactly what shape the final sump is.
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 27/6/13 at 01:11 PM Reply With Quote
I have produced lot's of 'shallow' sumps for Locost race engines. Remove 40mm from the bottom so it is level with the bell housing and add the new capacity to the front. The pick up will require modifying.........
nilocp
posted on 2/7/13 at 06:22 PM Reply With Quote
Thanks everyone, particularly Steve, sorted!!
Colin
