Author: Subject: Iva emissions fail
posted on 1/11/18 at 09:41 AM Reply With Quote
Iva emissions fail
Could anyone help? My kit has failed today on it’s emissions it was ok on co but failed on hc. How do I get these down It’s a carb’d zx1000 Would a cat help??
russbost
posted on 1/11/18 at 09:56 AM Reply With Quote
No, if it's failed on HC's it must be running very poorly generally, it should pass easily., albeit possibly only when rpm is raised a little
You need to check all usual culprits, ignition, carbs etc, but I would start with valve clearances, they closed up on both of my ZX10's & made them run like a bag of poo
cliftyhanger
posted on 2/11/18 at 06:40 AM Reply With Quote
I think balance can upset HC too.
If you can get hold of a balancer that connects to all 4 at the same time it makes life very easy. Remember to balanceat idle and just off idle to make sure the linkages are set correctly.
