Author: Subject: No spark...Zetec 1.7 SE
lordbenny
posted on 5/12/20 at 12:25 PM Reply With Quote
As title suggests...car was firing up perfectly then overnight it fired up but misfired, now it doesn’t fire up and I have no spark. Any ideas?
theconrodkid
posted on 5/12/20 at 01:25 PM Reply With Quote
CPS sensor or a dodgy wiring conection i would go for
who cares who wins
pass the pork pies
lordbenny
posted on 5/12/20 at 01:28 PM Reply With Quote
Not coil pack....as I was saying it was firing up but misfiring for a couple of starts but now nothing.
gremlin1234
posted on 5/12/20 at 03:05 PM Reply With Quote
has it run out of fuel?
lordbenny
posted on 5/12/20 at 03:19 PM Reply With Quote
No spark!
johnH20
posted on 5/12/20 at 03:48 PM Reply With Quote
Earths seem to be the root of most electrical problems. Its a pain I know but check everything relevant. If you are using standard immobiliser check key orientation. Good luck.
Tatey
posted on 5/12/20 at 07:56 PM Reply With Quote
I had a similar thing on my Haynes. I sent my carbs off for rebuild and when I got them back it wouldn't fire.
Turns out one of the crimped connectors providing power to the EDIS module had pulled out so I had no spark.
There is a check you can do with the coil pack wiring to confirm you are getting a spark signal. I'm not really sure what it is I'm afraid.
gremlin1234
posted on 5/12/20 at 09:09 PM Reply With Quote
No spark!
yea but often people state 'no spark' when they mean not firing. and infinitely better then a new post saying 'A'
lordbenny
posted on 9/12/20 at 01:19 PM Reply With Quote
So....I’m hoping that it’s the ECU fuse as fuel pump isn’t working either...Would you think this the culprit?
