Author: Subject: Omex 600 & zetec
ashg
posted on 26/12/13 at 06:48 PM Reply With Quote
Omex 600 & zetec
has anyone got a reasonable map/base map that they would be willing to share for an omex 600 running a zetec on jenvys? need to get one running tomorrow an it would save me quite a few hours :-)
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Jenko
posted on 26/12/13 at 10:06 PM Reply With Quote
Pm your email address and I may be able to help.....
MY BLOG - http://westfieldv8.blogspot.co.uk/
scutter
posted on 26/12/13 at 10:09 PM Reply With Quote
I have one for a ST170 if required.
ATB Dan.
ashg
posted on 27/12/13 at 12:30 AM Reply With Quote
its a standard 2.0 zetec with jenveys so im not sure if an st170 map will work
edit. the plan is to get it drivable so it can be driven to the rr for a proper setup but obviously the better the base map the less time it will need on the rr.
[Edited on 27/12/2013 by ashg]
martylemoo
posted on 27/12/13 at 09:10 AM Reply With Quote
Ask OMEX, they will send you a map. They did for mine.
Andy S
posted on 27/12/13 at 09:17 AM Reply With Quote
Think I have one here if you need one
ashg
posted on 27/12/13 at 09:35 AM Reply With Quote
i cant ask omex they are closed for christmas hence the ask on here ;-)
ashg
posted on 27/12/13 at 09:31 PM Reply With Quote
ok throttle bodies fitted loom made, ecu fitted car running. thanks out to andy and jeff who come up trumps with some base maps to get it running as we were stuffed with the vauxhall map on it and omex closed.
