Scuttle edging
craigdiver - 13/8/17 at 02:14 PM
Looking at starting to fabricate my scuttle, chassis is Haynes roadster / 442E hybrid so the glassfibre ones don't fit without cutting & infilling.
Going to make my scuttle by making a frame and wrapping some 1.2mm Alu over it. This will leave an edge above the dashboard, will it be ok to use safe-edge edging strip on this or will it need more radius for IVA?
mark chandler - 13/8/17 at 03:08 PM
That's what I did
Ali bulkhead
Ali bulkhead
Cut some MDF formers for front and back, spaced out 8" then hand formed the aluminium over it.
In the picture you can see where I made it to deep at the sides so I could hold it secure with a couple of screws before I started to batter down the edges.
craigdiver - 13/8/17 at 03:48 PM
Originally posted by mark chandler
That's what I did
Ali bulkhead
Ali bulkhead
Thanks Mark, I like the look of that - great job.
