Miss Fire 3500rpm under load
mark.silcock - 27/6/19 at 11:09 AM
The setup is Zetec RS1800 Twin 45DCOEs Nodiz Pro
We have a misfire at approx 3500rpm under load in all gears, when the the car is stationary the engine will rev higher but still starts cutting out around 4000rpm.
Initially thinking it was a fuelling issue. Things we have triple checked is jet sizes, venturi sizes, pump jets, float levels, and fuel pressure.
Jets etc installed:
34mm Chokes
50 F11 Idle Jets
145 Main Jets
170 Air Correctors
F16 Emulsion Tubes
4.5 Aux Venturi
40 Pump Jtes
200 Needle Valve
Facet Posi Flow 4-7psi Fuel Pump
Filter King Fuel regulator
Nothing has improved the issue so now looking at spark issues.
The Nodiz Pro has decided to be very unstable connecting to the laptop over bluetooth but the map loaded is for a 2.0 Zetec on carbs supplied by Nodiz.
Planning on double checking the timing this weekend.
Spark plugs are new.
Could be coil pack or HT leads?
Has anyone got any other suggestions?
[Edited on 27/6/19 by mark.silcock]
talkingshte - 27/6/19 at 11:28 AM
Check for corrosion or possible short circuits on your ignition circuit. Has the car been mapped at all? It would be good to get an idea of the air/fuel mixture as it stands.
mark.silcock - 27/6/19 at 12:10 PM
this is the map on the Nodiz
COREdevelopments - 27/6/19 at 12:40 PM
What Crank sensor are you using? I had similar issue with my megajolt setup, using a ford CPS. It would drive fine under light throttle and die momentarily under load. Idling it would rev high under light throttle up to approx. 4k. Replaced CPS and all returned to normal.
Hope this helps.
Rob
mark.silcock - 27/6/19 at 12:42 PM
Thanks, using the Zetec CPS
Will look into it.
talkingshte - 27/6/19 at 01:39 PM
Am I right in saying the Nodiz only does ignition? You'll need to get the fuelling table to see if theres a problem, just get a run done on a dyno.
All engines are slightly different, so cause someone else has the same parts and it works fine, yours might need some fine tuning to get it there.
I'd start by checking the electrical side, all your sensors (cps is a good shout) make sure the alternators good, earths, everything. Then move onto the fuelling side of things.
I hope I'm not telling you how to suck eggs!
mark.silcock - 27/6/19 at 02:17 PM
Yes the Nodiz only does ignition.
Planning on getting it on the dyno but would rather check everything first, dont want them chasing their tail identifying an issue if I can help it.
Dont worry any advice is good advice at this stage.
Worth noting we need to get it through the non cat emissions test for the IVA.
perksy - 27/6/19 at 04:15 PM
Is this when the engine is Hot and Cold?
Is it worse when either of the above applies?
Ugg10 - 27/6/19 at 04:27 PM
I had a similar problem, are you using a shielded cable for the nodiz to crank sensor with the shield connected to earth at one end? I wasn’t and was picking up interference from somewhere else that was causing a similar fault.
Schrodinger - 27/6/19 at 04:39 PM
Have you checked for a "Soft Cut"? in the ignition table?
bikecarbfred - 14/7/19 at 06:33 AM
i had a problem like this with megajolt trigger wheel set up. the vr sensor was picking up viberation at higher rpm
one of the cables in the vr sensor was loose. not only that the vr sensor was too far away from the trigger wheel.
i re wired the vr sensor at the trigger wheel side.
i re mounted the vr sensor so it was almost touching the trigger wheel.
the way i realised it was this, was on the laptop at high rpm i noticed the rpm digital gauge would go out of synch at high rpm after3500-4000rpm.
cheers
mark.silcock - 20/9/19 at 10:13 AM
So I still havent got to the bottom of this issue, have thrown at it new coil pack, leads, plugs, main jets, idle jets, chokes, needle valves, pump jets, fuel pump and nothing has made a difference. Engine temp doesn't make a difference.
Spoke to Nodiz and they dont believe its an issue with the ECU as it is only running off the crank sensor so the unit cannot detect any engine load, and seeing as it can rev fine with no load up to the limiter the unit is working as it should. Also the crank sensor seems to be fine. Have checked the soft cut settings and the launch control setting on the Nodiz and nothing is set to around the 3500rpm.
Other things I have tried are used a colourtune to tune the idle adjustment, sync'd the carbs, checked float levels, set the fuel pressure at the last carb to 2.5psi..... think that is about it.
So the assumption now is that the carbs need rebuilding, or I might go EFI as I have a Ginetta intake manifold and fuel rail sitting in the garage. Only issue with that is it would need a new ECU and fuel pump, also getting it under the bonnet will be a challenge.
Well that was more a of a vent than anything else but open to any suggestions....
jeffw - 20/9/19 at 10:15 AM
It will be the crank sensor, either it is faulty, too far from the crank wheel or not screened correctly. Change it for a start.
[Edited on 20/9/19 by jeffw]
RichardB123 - 20/9/19 at 10:17 AM
I dont see how its possible for a carburettor to cause a missfire like this.
mark.silcock - 20/9/19 at 10:18 AM
Why would load affect it though?
RichardB123 - 20/9/19 at 10:19 AM
What has changed since it was last running correctly?
RichardB123 - 20/9/19 at 10:20 AM
An ignition system is working hardest under load.
Just revving it up not in gear, the spark can be very weak or late/early and it would still sound OK
mark.silcock - 20/9/19 at 10:26 AM
That's one of the annoying things, it was purchased as an unfinished project and I never drove it in anger so dont know if it was like that previously.
I changed the engine from a 1997 1800 silvertop to a 91 RS1800 to get past the emissions other that that everything is as it was.
Looking through the previous owners diary and receipts he also spent a bit on servicing the carbs and different jets so I suspect it may have never run right. Also only paid £250 for the pair off ebay which seems cheap. He was going to put bike carbs on it.
mark.silcock - 20/9/19 at 10:29 AM
It just feels and sounds like fuel starvation.
mark.silcock - 20/9/19 at 10:34 AM
Will try one.
perksy - 20/9/19 at 06:23 PM
Does it missfire when the engine is hot or cold or does it make no difference?
I'd agree with Jeffw though and say Crank sensor
gremlin1234 - 20/9/19 at 08:15 PM
first check the fuel filters,
and as always, ensure the fuel is reasonably fresh, and charge the battery.
SPYDER - 20/9/19 at 08:37 PM
In an earlier post you said..."it is only running off the crank sensor so the unit cannot detect any engine load, "
So to be clear, it has no TPS or MAP sensor?
Or am I missing something?
It wouldn't be the first time.
If it was forced induction I might suggest reducing the spark plug gap. Worth a try?
I had a similar, but admittedly non load dependant misfire on my Megasquirt install, which was cured by
putting a 10K resistor in line with the VR sensor.
Float bowl fuel levels correct?
Many coil packs have an associated suppressor/capacitor attached? Does yours? Should it have? Is it faulty?
perksy - 20/9/19 at 09:12 PM
Faulty Battery isolator switch ?
Although they usually cause a high speed/RPM missfire...
mark.silcock - 22/9/19 at 07:16 PM
Engine temp doesn't seem to make a difference.
mark.silcock - 22/9/19 at 07:18 PM
Correct, no MAP sensor or TPS just the crank signal.
Checked the needle valve height but haven't measured the fuel level in the bowl.
mark.silcock - 22/9/19 at 07:19 PM
If it is no different with the new crank sensor I will video what it is doing.
SPYDER - 22/9/19 at 07:37 PM
Without any sort of load sensor the 3D ignition map you posted has no purpose. I assume it simply runs across the 100%, "full throttle" line.
mark.silcock - 22/9/19 at 07:39 PM
Runs across the top line from memory.
SPYDER - 22/9/19 at 08:46 PM
I'd prefer the bottom line.
mark.silcock - 27/9/19 at 04:50 PM
Ok another update.
So I first off checked the fuel levels in the bowls, one carb was off by about 5mm so adjusted the floats so they are both the same and are approx 26mm +-1mm.
Drove the car and again it's no different.
Crank sensor finally turned up and fitted it to the car.
Drove it and it's no different.
It wasn't running particularly well stationary tonight but still would rev past 3000rpm, probably needs an idle adjustment after the float level change.
Was suggested to try pulling the choke out while its not reving to see if extra fuel would make any different but that didnt do anything either.
Here is a sketchy video.
SPYDER - 27/9/19 at 07:26 PM
Could this "rev limit" be due to the Nodiz expecting a load signal and not getting one?
Did you try putting a 10K resistor across the VR sensor?
[Edited on 27/9/19 by SPYDER]
mark.silcock - 28/9/19 at 09:20 AM
I am not sure what you mean by VR Sensor? Ah crank sensor? No I haven't and what does that do?
The Nodiz is set to no load so its not expecting any signal.
[Edited on 28/9/19 by mark.silcock]
procomp - 28/9/19 at 01:19 PM
When you changed engine was the flywheel changed also or is the new engine and flywheel as it came as complete know running unit Ok.
Reason for asking is that when changing the CPS for a new one it might not be the actual CPS at fault but the housing it fits into. There are 2-3 different housings with differing CPS location within the housing for the Zetec and if the housing and flywheel are not in correct positioning to each other you will get what shows as a CPS issue but its not the actual CPS at fault but its location.
Hope that makes sense.
Matt
mark.silcock - 28/9/19 at 02:02 PM
Yeah it does make sense and something I had been thinking about. The flywheel was swapped over along with the crank sensor from the original engine that came with the car. Which from memory was a 1997 silvertop. The crank sensors did look the same but if the blocks are different then that would cause an issue.
How do I check?
Original engine was a Nov 1997
Current engine is a May 1992
SPYDER - 28/9/19 at 04:02 PM
The 10K resistor is a well known fix in the Megasquirt community. The problem is noise related and can cause the ECU to miss-read the missing tooth. It's more common on 60 tooth wheels but can show up on 36 tooth types.
To correct my earlier post.... the resistor goes INLINE with the crank sensor, not across it.
mark.silcock - 29/9/19 at 10:14 AM
Matt
Does that imply that the flywheels can be different?
If the CPS is the right one for the block (which is what I ordered) then it should be in the right place? But if the flywheels different as well then it would read wrong.
mark.silcock - 29/9/19 at 10:29 AM
We are going to check the signal with an oscilloscope along with the ECU signal to the coil pack.
procomp - 2/10/19 at 10:50 AM
Re flywheel differences, depends on a few things such as Fiesta, CVH, Zetecs 1.6 1.8 2.0 Etc Etc but we have had issues with swapping some lightweight flywheels from old to new engines when not changing the complete CPS and housing.
RichardB123 - 2/10/19 at 11:04 AM
If you are having flywheel trigger pattern woes.
Surely this aftermarket ignition system can work from a trigger wheel mounted to the front crankshaft pulley.
Like megasquirt/jolt etc.
mark.silcock - 2/10/19 at 11:55 AM
Not 100% sure its a Crank sensor issue yet, yes the Nodiz can run off a twigger wheel on the front pulley.
mark.silcock - 2/10/19 at 11:57 AM
What do you mean by housing? It bolts directly to the block, or am I missing something?
Schrodinger - 3/10/19 at 08:07 AM
The CPS fits into a housing which fits onto the block and there are different housings/CPS for manual and auto gearboxes.
procomp - 3/10/19 at 03:43 PM
Heres a pic of two. but have found over years 4 different ones.
Wont let me add pictures here but added photo to my page.
https://www.facebook.com/Procomp-motorsport-376574512390043/
mark.silcock - 4/10/19 at 08:59 AM
Ah I see, could not remember noticing that but luckily have a photo of the engine code that shows the mount.
Im guessing thats a good result as it should be close to the flywheel?
[Edited on 4/10/19 by mark.silcock]
mark.silcock - 5/12/19 at 06:42 PM
Update:
New Nodiz ECU installed and guess what its no different.
So I want to get to the bottom of making sure the crank sensor/housing and flywheel is the right combination.
What do I need to know and how do I check to get it right?
mark.silcock - 5/12/19 at 08:29 PM
Did they ever do an RS1800 Automatic?
Looking through the photos the original engine was a manual.
Can you tell from engine numbers?
would the engine even start with an auto housing?
[Edited on 5/12/19 by mark.silcock]
paulf - 5/12/19 at 10:02 PM
If you are using the advance curve on the top line of the map then it has probably got to much advance at 3500 and above , what happens if you reduce it to about 15 degrees across the map.The figures across the top of map are more like wht it should have on overrun.
Paul
mark.silcock - 5/12/19 at 10:05 PM
It runs exactly the same with the base map on the new Nodiz that is much more conservative.
We have loaded a few different maps and they have made no difference to the missfire.
mark.silcock - 6/12/19 at 12:03 PM
What about poor shielding from the CPS? What are the symptoms of that?
coyoteboy - 6/12/19 at 12:20 PM
Go back to basics on the ignition the way you have on the fuel, if you haven't already.
1) Check your static timing at idle. Check it doesn't wander. Use nodiz set up with values of 10 across the whole row to check it doesn't wander as you increase revs.
2) Check your crank sensor polarity is correct (it makes a difference to how the signal is interpreted).
3) Check your coil dwell time - insufficient dwell will cause misfire under load.
4) Check your spark plug gap - wrong gap will cause misfire under load.
5) Check for tracking at night in total darkness - tracking will be most noticeable under load but if it's visible at idle it needs fixing.
6) Buy/install a load sensor of some sort, using a 2D timing table is un-necessarily archaic, better to fix it now.
7) Running "too lean" with any of the above weaknesses can cause misfire.
SPYDER - 7/12/19 at 01:50 AM
Is there a "rising/falling edge" setting in the Nodiz?
mark.silcock - 7/12/19 at 12:50 PM
So I first want to get the Crank Sensor Housing question sorted as I need to know if I need to take the engine out.
Here is a video showing the timing marks through the CPS hole.
Can someone please compare, should they be in perfect alignment or is this how they are?
[Edited on 8/12/19 by mark.silcock]
mark.silcock - 9/12/19 at 11:13 AM
Here are the screens from the software. Note these are taken not connected to the car.
mark.silcock - 9/12/19 at 11:19 AM
Thanks, answers in bold
1) Check your static timing at idle. Check it doesn't wander. Use nodiz set up with values of 10 across the whole row to check it doesn't wander as you increase revs. - On the to do list timing marks are difficult to get to with out taking lots of bits off.
2) Check your crank sensor polarity is correct (it makes a difference to how the signal is interpreted). Checked and it was back to front, fixed and no different
3) Check your coil dwell time - insufficient dwell will cause misfire under load. Will look into it
4) Check your spark plug gap - wrong gap will cause misfire under load. New plugs with OK gap
5) Check for tracking at night in total darkness - tracking will be most noticeable under load but if it's visible at idle it needs fixing. Will look into it
6) Buy/install a load sensor of some sort, using a 2D timing table is un-necessarily archaic, better to fix it now. Maybe but wouldnt cause this issue?
7) Running "too lean" with any of the above weaknesses can cause misfire.Have run it lean have run it rich and its made no difference
mark.silcock - 12/12/19 at 01:07 PM
Can anyone confirm this is right?
mark.silcock - 20/12/19 at 09:52 AM
Had an oscilloscope on the crank sensor last night.
Signal looks fine and clean at idle and at high revs.
Image taken at approx 4000rpm which is higher than the miss-fire occurs on the road.
I think it's safe to put that to bed and move on?
mark.silcock - 14/1/20 at 01:25 PM
Update time.
Took the car to AP Racing Engines in Blidworth today and Andrew managed to sort the car out.
So it was running very rich and the main issue which I wouldn't have believed if I didnt see it for myself was the air filters!
Andrew had the car to a point he was happy with pulling 131bhp at about 5500rpm with the filters off, then put them on and the engine produced 76hp and wouldn't rev past 3500rpm.
He was staggered and so was I.
The two runs, bright yellow line filter off, dark yellow line filters on!
These are the offending filters, which have had very little use and not dirty.
https://www.ramair-filters.co.uk/shop/automotive/carburetor-itbs-automotive/sock-filters-automotive/twin-inlet-carb-socks-and-velocity-stack-filt ers/
Would never in a million years had guessed they were the issue, but of course everytime I road tested the car it had the filters on, and when working on the carbs in the garage the filters were off so would rev ok stationary then wouldnt on the road. I assumed it was fuel starvation not air starvation!
Still can't believe it myself, but at least the car is pulling nicely now and apart from the rain in the face I had a lot more fun drive home!
IVA time!
