RAW Striker Wheel offset
peter030371 - 10/7/14 at 08:54 AM
I am looking at getting some 13"x 7" Team Dynamics Pro Race 1.2 wheels for my Striker. What offset are others running on a sierra based front and rear end? I will be fitting 185/60 tyres front and 205/60 rear if that make much difference.
I would love to get 6" fronts but Team Dynamics say the do not get enough demand for this size which is a pity as a 185/60 Toyo 888 tyre is spec'd to fit a rim no bigger than 6.5"
INDY BIRD - 10/7/14 at 09:01 AM
I ran Caterham wheels on mine 8" wheels rear 6" front, had to run small spacer ie 5 mm on them on fronts to clear, offset 24 mm they fitted a treat
Pic below
striker caterham wheels
loggyboy - 10/7/14 at 09:13 AM
Will be worth a measure up to be sure. Or use a set of wheels you have already as a base point.
peter030371 - 10/7/14 at 09:16 AM
Thanks for that answer, I did have the same wheels in grey for my old Striker but sold them on as I really want black wheels!
Did you have to do any mods to the rear to get the 13" rims to fit?
INDY BIRD - 10/7/14 at 09:39 AM
If live axel you don't but with my IRS ar I had to reduce the height of the upright a small mod I think maybe some photos in my archive,
Sean
