Cable run floor mounted pedal box
John Bonnett - 11/10/20 at 09:29 AM
With the pedal box put in position the clutch pedal is close to the clutch actuating arm in the bell housing. A cable would have to bend through 180 degrees so obviously a long cable is necessary.
if anyone is running a floor mounted pedal box with a cable clutch I would appreciate any photos and information on what length cable they have used.
Thank you
John
steve m - 11/10/20 at 11:12 AM
I ran a long Ford Capri cable prob about 48" long, in a soft loop,
Never had any issues in 21 years on the road,
steve
John Bonnett - 11/10/20 at 11:27 AM
steve
Thank you Steve,
I was thinking that would be about the length needed. Did you get it from Burton's?
Kind regards
John
rusty nuts - 11/10/20 at 12:28 PM
I used a mk2 Escort cable on my car, been on it for 15 years or so. It goes through nearly 180 degrees .The Burtonpower website shows clutch cable lengths which may be of use?
steve m - 11/10/20 at 01:03 PM
I got mine from a motor factors, cant remember what spec
jps - 11/10/20 at 02:50 PM
This might help? https://meandthekitcar.wordpress.com/2019/03/15/pedals-3/
QC1010 worked for me, about £15 via eBay.
John Bonnett - 11/10/20 at 03:37 PM
Really good information. Thank you all for your replies.
John
PS The extra long cable now on order from Burtons. Great. Thank you once again.
[Edited on 11/10/20 by John Bonnett]
lsdweb - 11/10/20 at 06:08 PM
I used a pullrod on the Locost many years ago. The engine was solid mounted though.
Pullrod Clutch
Pullrod Clutch
[Edited on 11/10/20 by lsdweb]
John Bonnett - 11/10/20 at 06:15 PM
Pullrod Clutch
Pullrod Clutch
Funny thing, I was thinking about the very same design and in a way I would prefer a rod to a cable. Less likelyhood of a breakage at the most inconvenient time. Good point about having a solidly mounted engine which I don't have. I hadn't considered that but any engine movement could give a bit of clutch judder. So that's a downside that I hadn't thought of.
[Edited on 12/10/20 by John Bonnett]
steve m - 11/10/20 at 10:10 PM
A broken clutch cable, is not a problem, as its pretty easy to drive a manual car with out a working clutch, and ive done so at least twice,
sticking rods and stuff in the mix, will make an on the road repair fo the AA or like, a real PITA
John Bonnett - 12/10/20 at 06:55 AM
Cable it is Steve and on my car I'll make it very accessible if it ever needs to be changed.
