No stalk controls
Steve Lovelock - 14/11/06 at 10:45 PM
I had the thought of removing the Sierra stalks and using a row of rocker switches instead with the possible exception of an indicator stalk from somewhere like CBS. Only real reason is that I don't like the standard Ford appearance of the Sierra stalks. Any views on this?
ruskino80 - 14/11/06 at 10:50 PM
i changed mine recently to fit paddle shift -works fine put my indicator switchas on my paddles-check pic in my archive.
RazMan - 14/11/06 at 11:52 PM
Do a search on eBay for Chris Strong - he will mod your stalk switches for £30 ish Rescued attachment alloystalks.jpg
Danozeman - 15/11/06 at 06:55 AM
Theyr nice but not locost.
I used a rocker switch for my headlamps and kept the sierra indicator stalk. Doesnt look to bad.
U can glue an dalloy shaft into the switch like rays for less money, Im sure someon on here did it.
k33ts.
James - 15/11/06 at 09:03 AM
Just bear in mind one thing....
stalks are extremely easy to use! A lot more convenient than switches. Not having to take your hand off the steering wheel is very useful!
And as for having dash switches... I know of atleast one builder who can't reach them once strapped into his harness!
James
JAG - 15/11/06 at 09:12 AM
My car has all switches on the dash.
The only one I'd change is the indicator - like James said "stalks are extremely easy to use" and I would put the indicators on one if I could be bothered.
I guess that say's it's not a major issue but could be better.
zxrlocost - 15/11/06 at 09:14 AM
all in a days work
Marcus - 15/11/06 at 09:53 AM
Using A Manta column, I only have 1 stalk for the indicators / high beam / wipers (twist) and horn. The lights are on a rotary switch. Much neater than 3 stalks.
Stuart Walker - 15/11/06 at 04:07 PM
All mine are on the dash, no stalks at all. The indicators are on a rotary one (centre off, left / right), the main side and headlight switches on the dash and dip/main on the steering wheel, along with the horn.
I havn't driven with it yet but I can reach them all strapped in the driver's seat.
Stuart Walker - 15/11/06 at 04:17 PM
Dash Layout
Dash Layout
