Author: Subject: r1 5jj servo brake pick up
helinelly
posted on 12/10/14 at 07:40 PM Reply With Quote
hi guys im new to the site.....im putting a r1 5jj in my car and just want to know how you guys get a vacumm to the brake servo....do I get one from the carbs on the engine..cheers
adithorp
posted on 12/10/14 at 07:47 PM Reply With Quote
Very few kits have a brake servo and not seen a BEC with one.
http://jpsc.org.uk/forum/
CosKev3
posted on 12/10/14 at 07:51 PM Reply With Quote
As above.
A servo is usually connected into the inlet manifold between throttle body and engine,I can't picture how you could get a decent set up with the bike carbs as they sit directly onto head with no inlet manifold.
What car are you converting?
dave_424
posted on 12/10/14 at 08:16 PM Reply With Quote
You could tee all 4 of the vacuum ports in each inlet together and then run 1 pipe over to your servo which would give you the best bet of it working. As others have said though most people don't run a servo
