Author: Subject: Ford Wheels for Westfields and Ford Hub Kit Cars
Jibberingloon
posted on 30/6/15 at 07:04 AM Reply With Quote
Hi All,
Well this is my first post
I am looking at various wheels for my Wetsy, and was wondering will any 4 stud ford based wheel fit?
Escort / Fiesta / Focus / Mondeo etc?
I look at the Rimstock Pro Race wheels and they are 15x7 ET23-24, but a lot of the generic ford wheels are all high ET35-45 so will sit in 10-25mm
I assume I would have to run Hubcentric Spacers on these to get the offset right?
Mark
mcerd1
posted on 30/6/15 at 07:32 AM Reply With Quote
If you want OE wheels with the old ford fitment (4x108 with a 63.4mm centre bore) and ~ET24 then you need to think of an older generation of cars
Mk1 & 2 escorts, capri's.....
The mk1 focus has mostly ET52.5
Most sierra wheels are ET35 or ET38
loony
posted on 30/6/15 at 08:18 AM Reply With Quote
With the spacer you will get even worse offset: wheel ET 25 + 10mm spacer will give you offset/ET 15...
Lucas
kingster996
posted on 30/6/15 at 09:24 AM Reply With Quote
Can also depend on which model of Westy you have - for example Sierra SDV's use et 37/38 whereas modular builds tend to use et23/24.
If it's a Mazda SDV, they use 100 PCD, otherwise its std Ford 108 PCD (so Ford and Peugeot wheels fit depending on offset)
You can use spacers and longer studs to help if they sit in too far though.
http://www.willtheyfit.com/ is very handy for working out what fits too.
[Edited on 30/6/15 by kingster996]
I used to be indecisive, but now I'm not so sure
adithorp
posted on 30/6/15 at 12:50 PM Reply With Quote
You can also look at Peugeot wheels as they're the same 108mm PCD and often lower ET than Ford. (not sure on the centre bore)
If you want ET 24-25ish then yes, you'd need a 10-11mm spacer (and longer studs) on an ET35 wheel to get the same offset.
http://jpsc.org.uk/forum/
Jibberingloon
posted on 30/6/15 at 12:59 PM Reply With Quote
So my car is a V Reg car built by Terry Nightingale
Looks like Sierra diff and currently some 15" wheels
They look like these
And the fronts are ok but the rear sit in the arch a lot.
So think I either need spacers? or get some nice wheels
ianm67
posted on 30/6/15 at 01:05 PM Reply With Quote
Ford Puma wheels are suitable:
Always biting off more than I can chew.....
mcerd1
posted on 30/6/15 at 01:08 PM Reply With Quote
Originally posted by adithorp
You can also look at Peugeot wheels as they're the same 108mm PCD and often lower ET than Ford. (not sure on the centre bore).
Peugeot / Citroen have 65.1mm centre bores - you need adaptor rings to use them on ford spec hubs (lots of places sell them)
kingster996
posted on 30/6/15 at 03:47 PM Reply With Quote
http://parts-shop.westfield-sportscars.co.uk/index.php?route=product/product&product_id=834&search=set+of+4
On offer until Friday
