Author: Subject: Replacing master cylinder
j_mcvic
posted on 24/4/16 at 09:34 AM Reply With Quote
Hi all,
I need to replace my master cylinder on my Locost as its just started leaking. The seals were done pretty recently by the previous owner so I feel it may be time for a nice shiny one as I can't work out what it's from. There are virtually no markings on it. Posted up on a couple of ford Facebook pages and nobody can tell what it is from! It also looks like the rod has been modified in the past to make it fit with various nuts being welded to it!
So my question is... Does anyone know what this master cylinder is from? And what cylinders do folk run? I've got no experience with replacing master cylinder apart from the other night taking this one apart to clean it and put it back together. Which made the leak better but still weeping out a bit!
Picture of current setup:
Any help would be much appreciated!
Jamie
trextr7monkey
posted on 24/4/16 at 09:59 AM Reply With Quote
Looks like a Lockheed cylinder and servo as fitted to Mk2 escort and a host of BBritish Leyland type vehicles. Your local factor may be able to get one or check Burton power and Rally Design site . whip it off and measure the bore you will know where you are. The modifications to the rod are normally done to allow for the different thickness of bulkhead between a production car and a kit where the thickness may be greater.
Hth
[Edited on 24/4/16 by trextr7monkey]
