New Topic New Reply
Author: Subject: Certification for Suspension Components in the UK - question?
woodsy144
posted on 25/11/19 at 12:49 AM Reply With Quote
Hello,
Just have a question, in the UK do you have to demonstrate engineering for self made components such as control arms when you present your vehicle for registration?
ie FEA reports, physical testing reports
In AU we have to demonstrate to the certifying engineer that self made components meet a certain level, and was just wondering what is the process in the UK?
steve m
posted on 25/11/19 at 07:55 AM Reply With Quote
The answer is NO
However cars built post 1999 have/had to go through an inspection called SVA/IVA and if the tester saw some dodgy welding or poorly construction, the car would probably fail
steve
Mr Whippy
posted on 25/11/19 at 12:35 PM Reply With Quote
No chance, testing in service, then moaned about on here when the wheels fall off...
Even aftermarket OEM parts have no paperwork with them so could be make from old fridges and Chernobyl for all we know.
Saying that I've had original suspension parts on tin tops fitted by the manufacturer snap right off at the welds so there's no winning
Full certification and testing, that's why airplanes are so expensive.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
coyoteboy
posted on 25/11/19 at 05:30 PM Reply With Quote
Not required. Plenty of dangerously designed aftermarket parts out there.
Report your local potholes, it actually works!
big_wasa
posted on 25/11/19 at 08:01 PM Reply With Quote
I once see an Iva/sva inspector say to a builder “your welding is poo but there is plenty of it so it probably won’t fall of”
woodsy144
posted on 25/11/19 at 09:38 PM Reply With Quote
Very interesting.
Thanks guys
In Victoria (Australia) all suspension components have to be deemed fit for purpose.
For made components they must be either physically tested or proven by FEA / hand calcs.
The load case is at the contact patch,
- bump loads: 4g vertical;
- rut loads: 1g vertical combined with 0.6g lateral; and
- skid loads: 2g vertical combined with 1.2g skid (longitudinal).
- overturning loads: 2g vertical combined with 2.5g overturning
Mr Whippy
posted on 26/11/19 at 12:41 PM Reply With Quote
tbh those loads seem quite low
So when you buy, say a replacement wishbone for your car it comes with all this certification??? here your doing well if it's in a bag, the sign of quality...
posted on 26/11/19 at 04:55 PM Reply With Quote
quality...
Aint that true!
I've bought replacement front wishbones (ball joints and bushes already fitted) here in the UK before several times, certainly no certification given with them and if they come in a cardboard box or poly bag you're doing well.
chillis
posted on 27/11/19 at 10:58 AM Reply With Quote
This is not true. I work for a company whose business is certification and testing and we test a lot of aftermarket and generic replacement parts for many business lines and certify as required. Much of this is to do with covering the manufacturer in the event of failures and the subsequent claims. A court would expect the manufacturer to have conducted suitable testing of a product before sale.
It is however not a business area that is talked about much within the general public so it is easy to see how people may think aftermarket or generic products are not tested.
To answer the OP's original question, an enthusiastic amateur can make suspension and other parts but before the vehicle can be registered for road use an IVA examination of the vehicle must take place, though the components are usually only visually inspected.
HTH
Never under estimate the ingenuity of an idiot!
Mr Whippy
posted on 27/11/19 at 12:25 PM Reply With Quote
nope never seen once any testing cert for an aftermarket part, best I've seen is a bag and a bar code, as for stuff made in China hmm
New Topic New Reply
