Author: Subject: XFlow Throttle Linkage
The Doc
posted on 21/1/07 at 08:36 AM Reply With Quote
Anyone else fingd that the throttle linkage plate was sticking up too high for comfort?
This is a 1600 with twin choke Weber.
Any ideas?
Mike
Deckman001
posted on 21/1/07 at 12:00 PM Reply With Quote
Yes, that and the cable was stoping me getting the bonnet on, So I changed the carbs to R6 ones and now it's all sorted, sorry not the answer you were looking for I guess, but if the linkage is too high, try fitting the bonnet over the carbs as well
Jason
posted on 21/1/07 at 12:19 PM Reply With Quote
Don't have any problems with my Luego locost. How high is the engine? could be it's too high
Stuart Walker
posted on 21/1/07 at 01:07 PM Reply With Quote
Yep, I had this problem, the bonnet lifted up as you accelerated at first!!
Not too good, so I fitted a bulge. All fine now.
DavidM
posted on 21/1/07 at 05:53 PM Reply With Quote
I had this problem with the Motorcraft carb. I modified the bracket so that the cable came in just below horizontal instead of sloping down from above, if that makes sense.
You can just see it here: Rescued attachment 222.JPG
