Decent exhaust pipe cutter
Shooter63 - 3/6/17 at 05:04 PM
Can any of you guys recommend a decent exhaust pipe cutter must be able to cut 2.5" diameter stainless steel.
Shooter
craigdiver - 3/6/17 at 06:51 PM
Grinder + thin cutting disc???
britishtrident - 3/6/17 at 07:48 PM
I use the Silverline tail pipe cutter makes a clean cut if you don't rush it, but I have never tried it on SS
[Edited on 3/6/17 by britishtrident]
Smoking Frog - 3/6/17 at 08:19 PM
Same as above.
Wrap a sheet of A4 paper around the tube to get a even cut.
Mash - 3/6/17 at 09:01 PM
I bought an Evolution chop saw, recently, its really good and cuts tube really cleanly, at any angle you like.
I haven't tried it on SS either, but provided you get the corect blade I reckon it would do that too.
I got it from the Bay, refurbished for a really good price too
paulc - 3/6/17 at 09:35 PM
made all the cuts on mine with a hacksaw.
Found a web app that prints out templates for angled cuts.
Put in the tube diameter and the angle you want, print out the template, wrap it round the tube.
907 - 4/6/17 at 02:55 AM
Band saw with a bi-metal blade.
Lotus 907 manifold
ianhurley20 - 4/6/17 at 08:00 AM
Its called tube miter https://www.ozhpv.org.au/shed.html
nick205 - 4/6/17 at 03:23 PM
Ditto - I bought an Evolution saw new from Screwfix a few years ago. It cuts wood and metal cleanly with the same blade.
