Harness Eyebolts
Mix - 20/9/03 at 10:32 AM
Assuming they are correctly marked are there any problems using eyebolts to retain the shoulder straps of a four point harness ? I'm thinking SVA more than technical but all comments welcomed.
Mick
Sideways 2 Victory - 20/9/03 at 01:14 PM
I do hope theyre ok Mix as this is the setup I have too.
Merlin Motorsports shortened 4x4 willans kit supplied with eyebolts and spreader plates. - I have to use eyebolts for the clip style top clasp on the shoulder straps.
Dave
Peteff - 20/9/03 at 03:19 PM
We took one with the Willans 4 point clip on and it passed at Derby.
yours, Pete.
spy - 21/9/03 at 03:44 PM
Mick
I don't think I've ever seen any harness eyebolts (even those supplied with harnesses) with any markings to indicate their strength.
kingr - 28/9/03 at 06:45 PM
As a related issue (sorry for the hijack mix!) how do you get the eye bolts to point in the right direction when tightened down? Do you have to shim them or what? Also, what are the spreader plate made of? Steel plate with a thread or something a little more sophisticated than that? I was thinking I would get 1" high 1" diameter columns machined up which I could weld into the normal place (mine is 2" wide).
Kingr
spy - 29/9/03 at 09:40 AM
The eyebolts must be FULLY tighten against a solid platform, so if your fixing through GRP for example you need to remove it from around the eye bolt before it is fastened in. The eyebolts should be 'pointing' in the right direction so you need to find a washer/shim that will set it correctly when it is fully screwed in.
The spreader plates from places like demon tweeks seem nothing more that a nut welded onto a piece of 3mm plate.
Kingr
