Discovery 4 bush size RGX500211
TPG - 19/5/15 at 06:45 PM
I am identifying poly bushes suitable to replace knackered old rubber ones currently in residence.
1 bush
1 bush
2 bush
2 bush
..and they live here
mount
mount
I "THINK" that Disco 4 Rear Lower Wishbone Front Bush RGX500211 are the way to go. So, the title and reason for the post:does anyone have access to one to measure it please? Just the basics please. I will be hopefully getting a Powerflex PFR32-410 jobbies
powerflex
powerflex
...not had much help from Floflex it must be said. Anyway, I can/will make a new insert to suit and /or sleeve where it fits so that isn't an issue. If I have the size of the original bush I can check my meanderings and thoughts.
Thanks in advance.
mark chandler - 19/5/15 at 07:47 PM
Sharp tool and poly bushes lathe down very nicely, I used landrovers panhard rod bushes for my engine mounts.
TPG - 19/5/15 at 08:26 PM
Cheers Mark. I will be modding the bushes for sure. I just want to double check make sure there is enough of the bush to work with.
