Drive cleaner
The Baron - 10/5/11 at 07:22 PM
The oil filer on the wife's little street car managed to split and dumped a fair amount of oil over my drive (tarmac) i soaked up what i could with sand, then jet washed it (used a bit of washing up liquid too)
can anyone recommend any cleaning agents i can put on the dirve to try and shift the stain?
The Baron
macc man - 10/5/11 at 07:43 PM
I shifted an oil stain on block paving with a patio cleaner used 50/50 with water. Scrub well with a stiff brush. Leave to soak and rinse off. Be carefull with solvents on tarmac as it can disolve the tar and will break up.
Cubby - 10/5/11 at 07:50 PM
Brake cleaner great on concrete spray on brush in and hose off . Never tried it on tarmac so test a small patch first.
britishtrident - 10/5/11 at 07:56 PM
Soap powder --- scrub it in dry then wash off.
norfolkluego - 10/5/11 at 08:05 PM
Gunk would be best I would have thought
britishtrident - 10/5/11 at 08:18 PM
Gunk, brake cleaner --- both will disolve tarmac.
norfolkluego - 10/5/11 at 09:01 PM
Swarfega, rubbed in and washed off?
rusty nuts - 11/5/11 at 08:56 PM
Don't know if it would work on tarmac but I've just cleaned a really bad oil stain off of a concrete floor using oil absorbent granules and shuffling it around, has cleaned it up really well fot not a lot of money/effort
britishtrident - 11/5/11 at 09:01 PM
Kitty Litter same stuff but easier to get.
rusty nuts - 12/5/11 at 07:29 PM
Any motor factors stock oil absorbent granules and I get regular deliveries , to get kitty litter I have to go out and find a pet shop plus pay more
Had to clean a diesel spill off of tarmac today , the granules shifted 99% of it with no problems
[Edited on 12/5/11 by rusty nuts]
Krismc - 12/5/11 at 08:01 PM
if you have a Local gas/oil depo then Spil dry (oil absorbant granules) are around £4 for 25kg last you weeks - or if you in newcastle then i have 2 bags in my van, last me days if that! i drop oil every day in lift shafts, but it will only take the main part awy and not the stain - try washing powder for the stain or ambosol spray (also in my van) for when i get oil on customers belongings ie carpets, floors even walls some times lol
