OT Ryobi petrol multi tool.
roadrunner - 4/1/20 at 04:03 PM
I got this Ryobi multi tool last year and up to now it's been great.
Now I want to really use it, it's started playing up.
It starts a treat and ticks over fine but as soon as I open up the throttle it starts to dye.
I've had the plug out and cleaned it, also stripped down the carb and blasted it with carb cleaner .
There are no adjustments on the carb except for the idle.
But the bloody thing still won't run.
Anyone any ideas.
Thanks in advance
Brad.
Barksavon - 5/1/20 at 02:04 PM
Has it got an air filter fitted to it, if so try taking it out and running /revving it without it, I've got a petrol strimmer with a foam type filter which gets gummed up and causes the symptoms you describe
roadrunner - 5/1/20 at 03:40 PM
Already tried that.
I've got 2 things to try out. The high speed needle has no slot for adjustment but can apparently be turned.
The other is to remove the spark arrestor.
Barksavon - 5/1/20 at 04:14 PM
Also find with mine (Titan from screwfix) if I leave it to run for a few minutes on tickover the hesitancy when I rev it isn't too bad
roadrunner - 5/1/20 at 04:56 PM
I'll try it.
peter030371 - 6/1/20 at 08:47 AM
Maybe a daft question but are you using fresh (from the petrol station) fuel? When cold this can make a huge difference.
roadrunner - 6/1/20 at 09:01 AM
Yes.
