Zetec Oil Pressure Switch - Connector Identification
Tatey - 15/11/14 at 07:25 PM
Evening all,
I am currently trying to locate a connector block for my Zetec Oil Pressure Switch which looks like the following:
VE706051 Ford Focus Zetec MK II 1.6 Petrol 04 Oil Pressure Switch
Does anyone know what this kind of connector is called or is it a Ford specific one? In either case will it be possible to buy the other side of this connector? If not is it the case of finding a spade connector (female) which will plug into this or getting hold of another compatible sensor with a DIY friendly connector on it?
Dooey99 - 15/11/14 at 07:36 PM
go to a scrappy and ask for the plug off an old wiring loom and cut it with a few inches of wire on then just solder it on the end. thats what is do
19sac65 - 15/11/14 at 07:37 PM
Have you no local breakers yards
Take the switch with you to make sure the plug fits ,then snip it off
I doubt if they would even charge you
T66 - 15/11/14 at 07:46 PM
An ebay search for "zetec breaking" always works.....
Apply it to whatever your after, then email the seller for the specific part.
Ford Fiesta 03 Breaking Zetec
davidimurray - 15/11/14 at 07:46 PM
You can get them for free quite easily .........
http://locostbuilders.co.uk/viewthread.php?tid=194663
Tatey - 15/11/14 at 09:44 PM
Thank you very much for all the replies. I really hadn't considered the idea of getting one from a breakers. I've emailed TE Connectivity to get a free sample, if that doesn't work ill be heading down to my local breakers.
davidimurray - 15/11/14 at 09:47 PM
You just need to register with TE then use their sample ordering system.
Or buy from Mouser - http://uk.mouser.com/ProductDetail/TE-Connectivity-AMP/184042-1/?qs=sGAEpiMZZMvt1VFuCspEMhsCqXACm5kc
[Edited on 15/11/14 by davidimurray]
