Zetec PCV system
zetec7 - 16/6/06 at 05:08 PM
I'm using a Zetec 2.0 on Weber 45DCOE's on an Ehrlich igniton (haven't started it up yet), but I'm wondering about the large metal PCV cannister below the exhaust. It's normally vacuum controlled (with engine vacuum as the "signal" to release the pressure), but obviously with Webers, there isn't any. I don't want to have internal pressure causing seal leaks or anything.
I'm sure many of you (being an inventive and ingenious lot!) have gotten around this problem. Suggestions? Thanks!
Markp - 16/6/06 at 05:17 PM
Is this what you mean??
clicky
Mark
big_wasa - 16/6/06 at 05:40 PM
Yep there is pic of mine there with that bit bined. As you say it does bugger all with out the vacume to open it.
zetec7 - 16/6/06 at 05:46 PM
Pretty much...just want to make sure no-one's had problems with pressure buildup
Markp - 16/6/06 at 05:54 PM
no problems at all!!
Mark
lsdweb - 17/6/06 at 09:23 AM
Blank it off - that's the advice from Dunnell's and that's what I did.
