Author: Subject: Renaultsport Clio Engine Option
oldy
posted on 22/4/17 at 05:08 PM Reply With Quote
Hello all,
I have a Renaultsport Clio 182 engine mated to a Ford T9 gearbox.
The required bellhousing is a prototype at present.
Do members think this option would be attractive for new kit car builds or for re-engining existing cars?
Ugg10
posted on 22/4/17 at 06:02 PM Reply With Quote
Interesting combination, just a couple of thoughts -
Iron block so not the lightest and two stage variable valve to sort out with an ecu unless you have a solution using the OEM ecu and loom.
Not sure I can see any advantage over a duratec or even a st170.
Happy to be proved otherwise though.
[Edited on 22/4/17 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
loggyboy
posted on 22/4/17 at 06:07 PM Reply With Quote
Im massive clio fan, but the engine isnt what makes it great. They are a good engine but there are much more powerful and stronger engines out there. But if looking at gearbox options chech older volvo as they share a pattern, its popular to fit the Renault engines in older volvos for drifting.
Mistral Motorsport
big_wasa
posted on 22/4/17 at 06:39 PM Reply With Quote
Megane 225 should bolt up then ? No vvt and a turbo but I can't see a standard t9 lasting long.
dai1983
posted on 22/4/17 at 07:23 PM Reply With Quote
Cost of regular cam/aux belt changes would put me off. I have the genuine Renault tools which cost £140 and if the dephaser starts rattling that's £100 on top.
big_wasa
posted on 22/4/17 at 07:36 PM Reply With Quote
Yep they really are money pits.
Just done bottom swivel bearings, steering arms and track rod ends steering rack bush, new boots.
Still have the belts, clutch and track upgrades to do yet.
