water temperature sender
wandr - 20/12/17 at 04:06 PM
Hi all
I have a sender problem, the one fitted worked fine but has broken off, any replacements seem to big at 1/8 npt which measures about 10mm plus with a vernier, the one that has broken measures just over 9mm body and has a screw on type terminal with a black band on it, any one have any ideas what it might be
many thanks
nick205 - 20/12/17 at 04:38 PM
Seeing CVH in your profile I'm guessing it's a Ford engine.
If so either a Ford dealer or Burton Power should be able to tell you and most likely supply a replacement.
http://www.burtonpower.com/catalogsearch/result/?q=cvh+water+temp erature+sender
[Edited on 20/12/17 by nick205]
