Author: Subject: Trike conversion
ali f27
posted on 7/5/14 at 02:43 PM Reply With Quote
Trike conversion
Hi starting to get the parts together for janes trike i have 2 possible builds in mind my bike is a suzuki vz 800 and want to be able to convert it back if need be so starting with a second hand swig arm want to build back end up from that westwales trike shop do a vauxhall chain drive diff use vauxhall uprights shorter side drive shafts to keep trike not to wide but problem with hand brake as all front end stuff . The other way would be to use seirra diff chain drive and uprights off a 7 back end that would mean i could use seirra drums and would get easy hand brake do seirra 4x4 front short shafts fit rear diff would like thoughts of the collective
Problem is i now have an ICD in my chest and am not allowed to weld i would but every bugger would go mad.
That should have caused every body enough to think about.
Cheers Ali
