locost supplier for cleco fasteners?
alistairolsen - 30/6/09 at 09:30 AM
Ebay have 5 in any combination of sizes you want with pliers for about 30 quid
demon tweeks have 300, but in a set distribution of 75 in each of four sizes, with pliers and a tray for 52 quid.
Anyone know of anywhere cheaper?
Benzine - 30/6/09 at 09:58 AM
http://www.lasaero.com/site/products/article?id=O0273HUC5&from=sear ch
any use? I've not used them before so don't know what a good price is
alistairolsen - 30/6/09 at 10:02 AM
Cheers Benzine
pliers for a fiver and 33p for the fasteners...
thats more than the demon tweeks and less than ebay. Can probably get away with less than the 300, buy 100 fasteners and the pliers for 40 quid or something.
Any other suggestions?
Bluemoon - 30/6/09 at 10:06 AM
I used primary fasteners, they do thumb screw type; and are very helpful worth ringing up. Only needed about ten was enough to secure all that was required, they also do good quality Avex (think that's the name) multi grip rivets; so much better than normal Pop rivets.. But not quite as good as structural ones..
Dan
omega0684 - 30/6/09 at 10:28 AM
i got mine off ebay, cheap as chips
mangogrooveworkshop - 30/6/09 at 04:38 PM
u2u zilspeed as he did the last group buy for these gibbons
PHULL - 1/7/09 at 10:03 PM
http://www.theyardstore.com/
this has got to be the cheapest place I have got my clecos, I have thousands of them.
vinnievector - 3/7/09 at 04:58 AM
second the Yardstore there is also Browntools,
All above are aircraft tool suppliers.
the clecos are great for bracket s and small jobs but if say you want to pull the alu around the chassie the thumb ones are better you can get cleco power pegs and peg gun if you want to spend a bit .
