Author: Subject: YB cosworth complete engine package
hector
posted on 9/7/20 at 08:51 PM Reply With Quote
Here is complete engine package for a yb cossy as removed from my mk1 escort, it is a 205 block all new bearings, rebored and fitted with Wossner pistons, high pressure oil pump, T3 garrett turbo rebuilt and balanced, green injectors, L6 ecu, 3 bar map sens, complete engine loom and all associated wiring relays amal solenoid, air filter and all boost pipework etc, also incorporated with it is an inertia cut off switch for fuel pump relay, has brand new distributor and leads plugs.
Also included is airtec rad/intercooler +twin fans (fitted with standard cossy theremo switch) for mk1 escort, small coolant expansion tank, oil catchment/seperator tank, Has an big winged alloy sump
Starter motor is included fuel pump also included
currently fitted with 2wd manifold, included is a good 4wd manifold aswell,
Alternator is not included although the mount for it is, ignition coil is not included,
This engine will need running in as its only been started/run on my property! with this spec it should be approx 300hp
I am going NA with a different engine hence the sale, it would need to be collected. located in Plymouth
so basically its the whole package minus alternator and coil,
If you want any pics let me know your email address and ill send some to you
£7500 07465988853
Forgot to mention it is fitted with brand new heavy duty Burtons clutch!
[img][/img]
[Edited on 9/7/20 by hector]
[Edited on 10/7/20 by hector]
hector
posted on 3/9/20 at 06:50 PM Reply With Quote
Still for sale
£6300 for the lot or £6000 without the intercooler/rad
St Peter
posted on 16/8/21 at 04:03 PM Reply With Quote
Is the YB 4wd exhaust manifold for sale separately
