Author: Subject: Heat wrap Cable ties
MsD
posted on 30/4/11 at 03:42 PM Reply With Quote
I hope this is the right section...
Can anyone give me some advice on getting my metal cable tie's tight on my exhaust heatwrap?
Ive tried a few different ways, but nothing seems to make the tie's grip the wrap.
10 x EXHAUST HEAT WRAP STEEL METAL CABLE TIES - 360MM | eBay UK
Any help appreciated!
Thanks Mark
Daddylonglegs
posted on 30/4/11 at 04:04 PM Reply With Quote
Not used any myself, but can you not split it lengthwise at the end and tie it like you do a medical bandage? Just a thought.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 30/4/11 at 05:15 PM Reply With Quote
they are the same as mine, wet the heat wrap, wrap it on as tight as you can and then use pliers to tighten the metal cable ties.
hth
snakebelly
posted on 30/4/11 at 05:20 PM Reply With Quote
gave up with these and in the end used stainless lock wire, very secure and easy to fit even without proper wire locking pliers HTH
iceman26
i have got a tool at work to do it is the car on the road or were in preston are you and i can come round
with the tool + banding for you
macc man
posted on 30/4/11 at 08:03 PM Reply With Quote
I have used them several times and not had any problems. Could be a poor quality brand of ties?
flak monkey
posted on 2/5/11 at 08:08 PM Reply With Quote
Stainless jubilee clips.... the ties are rubbish
Sera
http://www.motosera.com
adithorp
posted on 2/5/11 at 08:22 PM Reply With Quote
As said there's a tool to pull them tight and then cut off the excess. You're welcome to come down and use mine but Icemans is probably easier to get to. Mind the cut end though, it's razor sharp!
http://jpsc.org.uk/forum/
oadamo
posted on 2/5/11 at 08:49 PM Reply With Quote
put a flat screwdriver edge in the little cut out bit on the clip, then use a pair of thin nose pliers to wind up the tie pressing on the edge of the screwdriver tightering the clip
adam
James
posted on 2/5/11 at 08:51 PM Reply With Quote
As above... used stainless lockwire myself.
Dont remember it being difficult to do with that.
JAmes
