Author: Subject: Westfield Mega S2000 2.5" inlet, Carbon silencer.
Gadgetman
posted on 17/3/21 at 10:45 AM Reply With Quote
A used, (approx 17000 miles), carbon silencer for the Mega S2000, it's in generally good condition cosmetically, but shows the signs you'd expect for the miles and several European tours. Thankfully the upper, visible surfaces of the carbon and stainless are all good. The lower edge of the stainless front looks fine when on the car, but up close shoes the expected slight pitting from normal use. It also, on the underside, bears the inevitable signs of getting a low car with luggage, and ahem, larger driver, on and off ferries etc - you can see where the stainless straps around the carbon have caught and dragged slightly, and wear the carbon sleeve has scuffed along the bottom. Again, these aren't visible in normal use.
Performance wise, when last used, normal noise levels, and no rattles.
Last time I looked on the Westfield Parts Shop these were between £460 and over £500! However, the Mega S2000 version is not currently listed!
I'll throw in the steel mounting bracket, but you'll need to source the bolt, tube and bobbin.
£250 plus delivery, though collection, (Covid safe etc would be possible) from Cheshire.
There's an album of photos, here https://photos.app.goo.gl/CFcwXqf4BhC24yiXA
[Edited on 19/3/21 by Gadgetman]
Gadgetman
posted on 26/3/21 at 10:15 AM Reply With Quote
It's getting in the way now, £225 ONO plus delivery.
Gadgetman
posted on 1/4/21 at 11:44 AM Reply With Quote
Sold
