Duratec Flywheel lock
peter030371 - 10/3/15 at 05:47 PM
Anyone got any good pictures of a simply, home made, tool for locking the flywheel on a duratec?
Tried my impact gun and the flywheel bolts won't budge so time to get the break-bar on it and errr brake something!
Badger_McLetcher - 10/3/15 at 05:55 PM
Not sure about the duratec specifically but in the past I've used a bit of thin metal with two holes successfully - one hole gets bolted to the flywheel, the other to the engine. You do have to be careful not to bend or damage anything though
davidimurray - 10/3/15 at 08:24 PM
My homemade setup
dave r - 10/3/15 at 08:51 PM
seen one somewhere, that uses the 2 bolt holes for the startermotor, and locks into 1 tooth of the flywheel
big-vee-twin - 11/3/15 at 08:33 AM
I did the same as Davidmurray but held it on one tooth.
keithjardine - 11/3/15 at 11:50 AM
My state of the art flywheel locking tool on an old zetec......
Angel Acevedo - 11/3/15 at 03:52 PM
And Locost...
I LIKE IT....
AA
peter030371 - 11/3/15 at 05:03 PM
Thanks all, some good ideas but keithjardine that is close to genius and I will give it a try tomorrow
rodgling - 11/3/15 at 05:06 PM
That may be close to genius but it doesn't use the awesome power of two hammers:
believe it or not this worked perfectly...
se7ensport - 13/3/15 at 11:12 PM
one hammer... flywheel swap
flywheel swap
dave r - 14/3/15 at 08:10 AM
made one for myself today, had to lock the engine whilst in the car (needed bottom pulley undone)
the 2 holes pick up the starter motor blots and the box section engages on the ring gear
