Su hif carb
Shooter63 - 13/1/18 at 10:29 AM
A bit of a long shot on here but has anybody got a su hif carb knocking about they don't need, all I need is part of the linkage but it's not available from anywhere, most parts are but not the linkage bit. Hif 38 or 44 will be ok as I'm pretty sure the part I need is universally fitted as long as it's from a single carb set up ( twins have different linkage set ups)
Shooter
martin500 - 13/1/18 at 12:00 PM
Have you tried Burlen? http://sucarb.co.uk/linkage-parts.html
Shooter63 - 13/1/18 at 01:57 PM
They were the first people I tried, no luck I'm afraid, but thanks
Shooter
40inches - 13/1/18 at 03:47 PM
This any good https://www.minisport.com/lzx1739-hif-carburettor-linkage.html
rusty nuts - 13/1/18 at 04:09 PM
Might be worth asking on a Mini or maybe the GTM owners forum?
Shooter63 - 13/1/18 at 05:52 PM
Thanks but that is the lever I have, it's the inner one I need
Shooter
redturner - 13/1/18 at 06:13 PM
That is the one that I use on my R1 carbs instead of the throttle pot...........
coozer - 14/1/18 at 04:07 PM
I've got a v8 manifold with two su on, what bit do you need?
