Wanted... Blacktop head.
furryeggs - 12/6/19 at 10:10 AM
I’m after a 2.0 blacktop head for my ST turbo build. Its on a locost budget so needs to be serviceable with cams.
can collect within 40 miles of LE14 or arrange courier.
whats about?
big_wasa - 12/6/19 at 06:52 PM
Have you got an St head ?
I may be up for a swap, I’ve already fitted the st inlet valve springs and tested it.
furryeggs - 12/6/19 at 07:13 PM
i have a complete head, inlet and exhaust, most of the loom, g/box and every other bit off the engine that the guy i bought it off couldn’t be bothered to remove .
big_wasa - 12/6/19 at 07:31 PM
Yes the bits aren’t worth a lot. I sold my st heads, one only made a pound
Don’t underestimate getting all the bits in a 7. The turbo is the easy bit.
furryeggs - 12/6/19 at 07:48 PM
Up for a swap if you decide to...
I’ve taken a lot of measurements and started to plan the layout. Should be able to make it all fit?
big_wasa - 12/6/19 at 07:58 PM
Yep,
Have you taken yours to bits yet ?
furryeggs - 12/6/19 at 08:41 PM
everything is off apart from the timing belt and head...
