Author: Subject: WTD - C/F Effect Offcuts
Dick Axtell
posted on 5/9/12 at 03:49 PM Reply With Quote
As per title, but has to be 610mm long at least, and min 40mm wide. Have already browsed the Bay, and most offered there seem to be too big (i.e too much wastage).
snakebelly
posted on 5/9/12 at 05:34 PM Reply With Quote
remind me via u2u on saturday when im up the workshop might have some offcuts opf the real thing lying around
loggyboy
posted on 5/9/12 at 06:02 PM Reply With Quote
Is £5.23 to much?
VINYL STRIPE 100mm BLACK CARBON FIBRE SELF ADHESIVE | eBay
Mistral Motorsport
Dick Axtell
posted on 6/9/12 at 04:18 PM Reply With Quote
Thanks loggyboy, and snakebelly.
Loggyboy - vinyl wrap won't fit the bill. I need some trim to cover cockpit side rails, in prep for the IVA test.
Snakebelly - will U2U in due course, 'cos the plastic rigid stuff would fit the bill. Hope it can be heat moulded to fit.
40inches
posted on 6/9/12 at 08:50 PM Reply With Quote
I used ally cope moulding, covered in di-noc vinyl.
Dick Axtell
posted on 7/9/12 at 07:40 AM Reply With Quote
Thanks for that suggestion. Will keep it in mind.
mikeb
posted on 18/9/12 at 03:10 PM Reply With Quote
http://www.clickmetal.co.uk/Angle-Types/Mouldings/Aluminium-Cope-Mouldings/p-16-8-16/
I'm looking for the same stuff.
I'm sure I have seen some carbon ones somewhere but plan B looks to be the cope moulding covered in the carbon wrap.
Which size moulding did you go for 40, did it need to cover poprivets on the top of the side panels?
mikeb
posted on 18/9/12 at 03:12 PM Reply With Quote
http://www.carbonmods.co.uk/Products/Carbon-Fibre-Kit-Car-Sill-Protectors-(Pair)__CMSPWSTFLD.aspx
bit pricey though
40inches
posted on 18/9/12 at 04:21 PM Reply With Quote
No2 for the flat section, and 9 for the curved bit. I bonded the side panels on, so no rivets, but for a few that are countersunk.
[Edited on 18-9-12 by 40inches]
mikeb
posted on 18/9/12 at 07:38 PM Reply With Quote
Did number 2 need trimming back from 38mm. I fancied no9
40inches
posted on 18/9/12 at 07:54 PM Reply With Quote
No, I have panelled the inside with ally and Horse Box lining, so fits just right. No11 as an option?
Soundproof carpet machine cut pieces mouldable kit car | eBay
No9 over wheel arch and No11 across back, behind seats, painted satin black.
