Author: Subject: K Series 1.8 RWD Conversion
Hammy360
posted on 23/5/17 at 09:15 AM Reply With Quote
HI all,
Are there any good threads/stickies on how to convert the 1.8 k series to rwd using OEM loom, ecu and inlet?
H
Hammy
matty h
posted on 23/5/17 at 07:13 PM Reply With Quote
Use the standard engine loom which has a multi plug on it to disconnect from main loom, match up the wires from the car and fit the other half of the multiplug to the main car loom.
Try metro power for lots of info.
Regards Matty
Hammy360
posted on 23/5/17 at 08:20 PM Reply With Quote
Thanks Matt,
Is there a resource on LCB like there is for the Zetec, I cant find one. Metro power looks good but obviously RWD conversions is what Im really after.
[Edited on 23/5/17 by Hammy360]
Hammy
matty h
posted on 24/5/17 at 12:34 PM Reply With Quote
Do not think there are that many people running the k series engines.
I have some experience of fitting them in 7's.
What do you need to no.
Regards Matty
posted on 24/5/17 at 02:52 PM Reply With Quote
Caterham have a k series in them so should be plenty if resources out there
Hammy360
posted on 24/5/17 at 03:31 PM Reply With Quote
Regards Matty
Hi Matty,
More looking for a good resource to follow, investigate and plan
Hammy
Jed
posted on 24/5/17 at 04:36 PM Reply With Quote
Look for "K Midget" stuff. It is quite a popular conversion and most use a Caterham bell housing and Type 9 gearbox.
scimjim
posted on 24/5/17 at 04:46 PM Reply With Quote
Mk2 Reliant Sabre have the K series too - Caterham Bellhousing and type 9 with modified metro loom. I'm currently fitting one to an SS1 (previously CVH powered).
matty h
posted on 24/5/17 at 07:51 PM Reply With Quote
I am running tweaked 160vvc standard injection, caterham bell housing and v6 type 9 box.
With wosp starter, standard Ali sump, roller bearing spigot bearing homemade engine mounts with polo radiator along with freelancer remote thermostat.
If using the caterham bell housing you need the long shaft gearbox v6 type 9.
Very under rated engine once head gasket issues sorted.
Regards Matty
[Edited on 24/5/17 by matty h]
