Fishmouth
Daf - 29/12/13 at 05:15 PM
Just thought I'd share this with everyone as it may be of use to someone: I wanted to "fishmouth" some of the tubes on my roll cage but didn't want to fork out on an expensive tool and I don't have a printer at home to use the online tube calculators (I could have gone in to work to print it - but it's Christmas and on principal I'm not going to set foot in the office!!)
So! I simply took a block of wood and drilled through it with a hole saw (the same diameter as the cage) then I drilled a second hole at 90 degrees to the first one. If you push the tube into one of the holes - bingo you have a template to draw around!
This has probably been covered before but I never came across this "technique" when I searched
MikeRJ - 29/12/13 at 05:53 PM
If the tube and a bi-metal saw were a snug fit in the wooden block you might even be able to use it to do the fish-mouthing.
Benzine - 29/12/13 at 07:01 PM
Locost version of this is uncooked spaghetti with rubber bands/sellotape:
Daf - 29/12/13 at 07:04 PM
Daf - 29/12/13 at 07:05 PM
I LIKE that!
Nosey - 29/12/13 at 08:35 PM
Yep, very locost and very handy way out!
speedyxjs - 29/12/13 at 09:26 PM
Excellent thanks for this tip!
Saimonisha - 27/2/14 at 08:39 AM
Hai, I agree with you. Really useful tips. Thanks .
