metal at B and Q
stephen_gusterson - 24/10/02 at 10:26 PM
I was in my 'local' b and q at Northampton today. Its one of those really really really big ones you cant find anything in cos they are really really really big.
Tucked away in there was a lot of steel metal strips, angles and tubes. Came in about 2 and 3 foot or so lengths, various profiles and wall sizes. Didnt seem to have wishbone sised - nearest was 25mm with 1.5mm walls.
Thought this tidbit might be useful if you need that bit of braket or strip.
atb
steve
Liam - 24/10/02 at 10:37 PM
Do they have 12mm thick steel plate?? =)
I need some for my adaptor plate but have no idea where 'the man in the street' gets a small quantity of such stuff. Any ideas?
Also need some 5mm plate for diff mounts etc. Maybe some 3mm plate too...
Liam
interestedparty - 25/10/02 at 01:52 AM
My local steel stockholders has a guillotine for shearing sheets of plate steel to the size their customers require, and next to it is the offcuts rack! The first couple of times I made it clear that I was paying cash and I was allowed to pick out whatever I wanted, now they recognize me.
For the 12mm you will be wanting ally. I haven't needed anything like that myself but the first place I would look would be anywhere where stuff like that was being cut up and off-cuts were inevitably being produced. Non-ferroues fabricators etc. Could be that Merlin would be worth a try, his laser is used for cutting everything from steel to MDF
John
Simon - 25/10/02 at 01:00 PM
Chaps,
Any one in the country, I'd recommend (for those small extra bits you might need) that you try your local forge.
I got just over a sq foot of 6mm plate and similar amount of 3mm for £3. I thought that was reasonable.
Simon
Viper - 27/10/02 at 03:32 PM
Let me knoe exactly what you need i might be able to help..
Peteff - 3/11/02 at 11:44 AM
I use the local steel stockist ( Twiggs, Matlock or Hammer Goodlad). They usually have a section for offcuts. I asked if they had 3mm plate in the scrap section and the salesman replied " We don't save scrap, only usable offcuts". They will also tell you the performance specs if you are bothered about details.
James - 4/11/02 at 12:01 PM
I went round to the local steel fabricator (quite interesting to see all the 'projects' they were working one) to ask about raiding their bins.
Manager said no as they had them taken away and re-cycled. I said that I was more than willing to pay and he reckoned that I wouldn't pay them as much as he'd get scrap!!!
What a load of bo****ks! Scrap steel metal is about £7 a tonne isn't it? Well I can assure you he'd have got a better rate for it than that from me!
James
David Jenkins - 4/11/02 at 01:37 PM
They're probably scared of the "health and safety" issues - if you slip and injure yourself then they're liable.
Saying that, most places round my way will cheerfully root around for offcuts if they're asked nicely.
You must have found the local jobs-worth!
